Question about Pride Jazzy 1113 Power Chair
How can the speed be adjusted for a jazzy select hd
2 Suggested Answers
  • 692 Answers
SOURCE: How do you dial up the speed on the jazzy select 6
jrw if you are asking to increase the programmed speed of the chair then you need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased Hope this helps you
Posted on Oct 18, 2010
How do you lower the seat on a jazzy select power chair?
See the links
[PDF]Jazzy Select Series - Pride Mobility
https://www.pridemobility.com/pdf/owners_manuals/...jazzy/us_select_series_om.pdf
Jazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: ... setup of this power chair and must perform all of the procedures in this manual. .... Use only AGM or Gel-Cell batteries to reduce the risk of leakage or explosive.
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_om.pdf Reduce your power chair's speed when driving on uneven terrain and/or soft .... The Jazzy Select Series Power Chair has two main assemblies: the seat ...
Comfort Adjustments; Seat Height Adjustment - Pride Mobility Jazzy ...
https://www.manualslib.com > ... > Scooter > Jazzy Select gt > Owner's manual Pride Mobility Jazzy Select Gt Manual Online: Comfort Adjustments, Seat Height Adjustment. ... power chair and made any necessary adjustments to suit your specific requirements. ... Raise or lower the seat post to the desired position. 9.
Jun 04, 2018 | Select Health & Beauty
How do i speed up my jazzy select gt
Only by buying a faster model. They are powered by electric motors that are rated for a certain top speed. Any 'race tuning' is likely to reduce the life of the motor.
Also that is a low speed scooter. You would need one with decent steerable handlebars. Yours would probably unstable and difficult to control at speed.
Jul 28, 2016 | Pride Jazzy Select Gt With 2 Batteries In...
I just to make it go faster going back, the company adjusted but is out of business
You are going to need a programmer to adjust the speed. They are available used on-line but are pricey for single use. Find another local dealer and visit them. They will have the appropriate programmer and should be able to adjust the programming, usually at no charge.
Oct 18, 2014 | Pride Jazzy Elite HD
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
How do I slow down my power chair
You may have a faulty speed control depending on the model. There are hand held programmers that are used to adjust the speed and other parameters. Your local dealer or mobile technician should be able to make that adjustment for you.
Jun 20, 2014 | Select Jazzy Used Electric Wheelchair
Increase the speed
1) Press the speed button (two lightning bolts) up to 5-lights.
2) Get larger tires.
3) Have a dealer reprogram the controller - requires PGDT PP1 or Quantum programmer which is a dealer only item.
Jan 21, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Oct 17, 2010 | Pride Jazzy Select 6 Indoor Power...
My father has a jazzy select power chair. The spe...
You will have to take it to a mobility dealer to have it programmed
May 14, 2010 | Health & Beauty
The joystick is not sensitive enough, there is a pause between the joystick movement and the motor response. Jazzy 1120 how to adjust it?
The Jazzy wheelchairs have programmable controller. This includes the length of the pause before moving, speed, acceleration speed and deacceleration speed. You usually need a programmer to change the programming. You supplier should have one. For your nearest supplier have a look at the pridemobility website: www.pridemobility.com
Apr 21, 2010 | Pride Mobility Products Used Jazzy...
I have a Jazzy Select model. Fairly new. It
It could be that the acceleration is set to low. This setting adjusts the time it takes for the chair to reach maximum speed that you have selected on the joystick. With a low setting, it takes it a few seconds to get to maximum. Reprogramming the acceleration to a higher setting decreases the amount of time for the chair to hit max speed. You will need a PP1 handheld programmer from P&G drives technology to change the settings, or take it to a local DME specialist who will usually have a programmer to reset the joystick.
Oct 28, 2009 | Select Jazzy Used Electric Wheelchair
Pride Jazzy 1113 Power Chair Logo
211 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
