Question about Child of Mine by Carter's Brookline 4-in-1 Fixed-Side Crib, Chocolate
Where might I find hardware for discontinues cribs?
NEED FULL SIZE BED RAILS FOR DISCONTINUED CRIB, LULLABYE, COCO BEAR IN ESPRESSO COLOR...WHERE TO GET? COMPANY OUT OF BUSINESS
Nickki, im having the same issue. Same crib as you. Where did you end up purchasing them?
Oct 22, 2013 | Baby Gear
I have a legacy crib from 2002 model no. F37101.53 golden oak and I want to convert it to the full size bed and I need the side rails.
I have found that Baby's Own Room has extensive knowledge about crib conversion rails. They carry rails for discontinued & new cribs.
Aug 27, 2012 | Baby Gear
Bassett crib model 5530-0621 purchased in 2007- how to convert to day bed? Currently have it set up as a crib
If you don't have the rails to convert, Bassett discontinued the crib in2008. You can convert it using a standard metal (bolted) frame found in mattress or furniture stores. I called customer service today and found this information. 7/15/2013
Sep 05, 2011 | Bassett Baby Gear
I have a Child Craft Model F31111.10 crib that I want to convert to a twin and need info on bed 6444, rails and conversion kit pls.
Child Craft Cribs & Accessories:
www.babysownroom.com
When it comes to Child Craft products crib conversion rails they can get the low down for you. Give them a call or email - very prompt service and knowledgeable. I have a discontinued crib and NO CRIB #. With a little bit of work though Baby's Own Room got the answers for me and I promptly ordered the conversion rails I needed.
Oct 05, 2010 | Child Craft Crib 'n Double Bed
Help! Pottery Barn discontinued Madeline crib
I plan to list one of the Madeline Conversion Kits in the Antique White on ebay tonight. Just do a search for this item or search under my store "L Decor and More".
Dec 31, 2009 | Pottery Barn Kids Dana
Hello, i have a pottery barn thomas crib and the bar does not go up and down any more it is only a year old and I contacted pottery barn and they said there is nothing they could do. Also I wanted to...
We may be able to help you with the dropside hardware. In order to determine the type of correct hardware required for your crib, we will need to ask a few specific questions. If possible, please call us when you are with the crib for direct assistance at 800.205.9642 or 800.772.1041. Unfortunately, we do not carry conversion rails at this time. Many cribs do convert to full size beds by using a standard metal bed frame (often called a Hollywood bed frame) and using the non moving side of the crib as a headboard. However, we do not have information specific to your crib to be able to say for sure.
Sep 20, 2009 | Pottery Barn Kids Dana
Crib 90221
http://web.archive.org/web/20060617152205/kinderkraft.com/pdf/discontinued/305.pdf
Dec 02, 2008 | Kinderkraft Vermont Crib
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
KinderKraft crib
http://web.archive.org/web/20060803064940/http://kinderkraft.com/
This website has all of the older model and discontinued model cribs instruction manuals.
Feb 23, 2008 | Kinderkraft Vermont Crib
Kindercare Crib Instructions
This website has the instruction manuals for all older and discontinued model cribs.
Feb 13, 2008 | Kinderkraft Vermont Crib
Child of Mine by Carter's Brookline 4-in-1 Fixed-Side Crib, Chocolate Logo
54 people viewed this question
Top Child of Mine by Carter's Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Child of Mine by Carter's Baby Gear Expert? Answer questions, earn points and help others
