Question about Eureka 5849A Boss Bagless Upright Cyclonic Vacuum
Have a loose clip and plastic piece in case after cleaning brush. Where does it belong?
Removed brush case to clean lint and string wound around brush. White plastic piece and brass clip fell to bottom. All ten screws are in hand. Where do the to pieces go.
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: cracked
I'm afraid that you will have to replace the base unit, part #62577, would sell for around $25. Once it cracks, then it is weak and will affect the brush roll and belt.
Posted on Jan 22, 2008
SOURCE: Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Posted on Jul 23, 2009
SOURCE: when I took the base cover off the vacuum to clean
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Posted on Sep 22, 2009
  • 500 Answers
SOURCE: I opened the bottom to replace the brush (which
Hi sdibowitz,
I do not know if this will help, but here is a exploded view of your vacuum cleaner.
LINK
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Sep 09, 2011
How can I remove the roller brush to clean it?
While not removing rollers, my method of cleaning them involves regular attention to prevent build up. Sometimes long hair or threads get wound so thickly & tightly the roller gets stuck & won't turn. If I can't unwind enough by pulling a few threads at a time, I'll cut a bit & pull it away a bit at a time until the mess pulls free. This is especially tedious if it gets caught at the edges in the rotation mechanism. That can be one piece of thread at a time, tugging gently & cutting away the jam until you can free it. As for the brushes themselves, sometimes a wide toothed comb will clear clumps of pet fur & rug lint from each strip of brush on the rollers, making it easier to see & remove long, wound tightly tangles.
Jan 17, 2016 | Vacuums
WHY DOES metal spindle BURN
Sounds like the rotating brushes are stuck. Maybe something is wound around them. ie: bits of carpet or a piece of string or line?
Jun 28, 2014 | Bissell Vacuums
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
Brushes don't move. vacuum motor works
The brushes on the roller are driven by a wide, short rubber belt. These belts get old, worn, overheated, and break periodically.
It should be a fairly simple matter to unscrew & remove the plate, revealing the belt and roller assembly. You can get a replacement belt at Sears or nearly any vacuum shop.
While replacing the belt, it would be a good idea to take scissors or a knife (careful!) and remove the hair & other material that's wound around your roller. One thing that can cause a belt to break is when you're vacuuming & accidently pick up a string, a shoelace, a piece of cord... you know how fast that gets wound around the brush roller and locks it up? At that point, the belt is still trying to rotate the roller (which won't rotate)... and within seconds, the belt will get extremely hot. This can cause it to break, or reduce its life significantly.
This should be an easy fix, requiring nothing more than a replacement belt and a screwdriver. Good luck!
Mar 03, 2011 | Kenmore 31913 Progressive Direct Drive...
The beater bar doesn't rotate
If you have anyone in your house with long hair you'll probably find that it has hair wound around the shaft that spins. It's possible to take the whole thing apart & strip it down to the bare shaft & you don't need any tools. Turn the head upside down, and slide the flat clip that is at the back of the underside further backwards to unlock the back of the bottom plate. Then turn the two round latches on the back of the cross-arms of the head about 1/4 turn anti-clockwise, this will unlock the front edges. You should now be able to remove the bottom plate of the head. Once you have the head off, remove any hair and dust you can see, and if you hold the two ends of the beater and twist them gently against each other one way or the other, you will hopefully find that the beater comes loose on the shaft and the two black beater sleeves with the brushes on them can be slid outwards & removed. Once you've taken them out, thoroughly clean them (you can wash them in water) and carefully pull out any hair that is wrapped around the shaft, bearing in mind that some could have gone in under the edge of the plastic part that the shafts poke out of. Once you've got everything as clean as you can (I washed all the pieces of the head) and dried it all off you can put it back together again in the opposite order that you pulled it apart.
Dec 30, 2010 | Dyson DC11 All Floors Bagless Canister...
THE BRUSH ON MY HEAD FOR THE SEBO K1 HAS STOPPED SPINNING WHY???
Check the brush roller at each side to see if threads are wound around it. Also, check the brush to see if there are threads wound around it. This is what generally stops the brushes from spinning. It will take sometime to unwind the threads/lint and you may need scissors and tweezers to fully remove all of them but it will be worth it!
Nov 01, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
Please provide a Thumbs Up if this solution is of help to you. Paul
Oct 10, 2010 | Bissell Upright Vacuum - The Pet Hair...
How do I open the Turbobrush attachment on my Miele vacuum?
Loosen& remove 4 screws at bottomof turbo brush After cuttingventangledthreadvthrough crosswise with sissors. Turn turbo brush over gentlyon an even surface. Carefully separate and liftvoff upper casing. Then remove stuck threads.reassemble lift upper casingto bottom plateand pressinto place.turn unit over topside down and replace screws.
Jul 04, 2009 | Miele S251i Plus Bagged Canister Vacuum
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Eureka 5849A Boss Bagless Upright Cyclonic Vacuum Logo
587 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
