Question about FUJIFILM FinePix AV200 / AV205 Digital Camera
No display, but photo can be taken
The back light of display flicks one time for millisecond, after that no display, but photo can be taken.
  • 57 Answers
If you have your LCD turned on and it only 'flicks one time for millisecond, after that no display'...your LCD is dying and not worth the repair.
Posted on Jun 20, 2014
So I know how to use the camera just not the lighting switches I tried youtube but they are all pathetic the model is a onestep SE autofocus 600 polaroid! Thanks
Here's how to find out. Flick the switch one way, and with the camera sitting in one spot, take a photo, now flick the switch the other way without moving the camera, and take another photo. The darker one is for bright light, the lighter photo however, is for low light. I hope that helps
Nov 25, 2012 | Cameras
Why does a photo display with a wrong date in Lumix Simple Viewer
Once the photo is date stamped that is a done deal no changing it.
Jul 28, 2017 | Panasonic Lumix DMC-FZ18K Digital Camera
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
On the viewfinder, parts of the picture flashes black.
It sounds like you have the display set to show image "highlights", this is a mode that shows parts of the picture that has become over exposed and have no detail contained within that area, in other words the parts of the photo that are pure white.
The camera Highlights as one of several different modes that can be flicked through after looking at a photo you have taken. hope this helps  Ian
Sep 07, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Display time and date on photo when its taken and printed
Hi, I have the same problem and I was told it works in a postcard mode. Try it.
May 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Problem with display being white...but!
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 13, 2008 | Canon PowerShot A60 Digital Camera
Canon digital rebel 300D silver body
Sometimes if you take photos against harsh light, it results in too much Contrast and makes the photos look in B&W. Please explain more details of the problem you are facing.
Dec 27, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Photo recognition
try using a CF card reader ... when you hook the CF card reader to the PC .. it will open up the cf card as a drive.. you can download the pics by copy and paste...
reformat the card after that
Nov 28, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Black screen when viewing photos taken
When the picture does not display - do you see the normal text and icons that you would expect to see? Or, is the screen completely blank?
Feb 22, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
FUJIFILM FinePix AV200 / AV205 Digital Camera Logo
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
