Question about Panasonic ER 153 Hair Trimmer
HOW TO TROUBLE SHOOT FOR CHARGING LIGHT IS NOT WORKING
Jazzy wheelchair scooter 1450. Why does it go crazy with flashing (charging lights)?
Hi Emilee,
The lights flashing crazy, may mean you have locked out joystick. to unlock, try first, turn on joystick and push horn button twice right away. if that did not work, try turn on and push lever forward all the way wait until it beeps, then back all the way until it beeps again. that should do it. If not then count how many lights are blinking and how many times it blinks. consult owners manual trouble shooting guide for answer, or call 800-800-8586 Jazzy tech
Mar 12, 2016 | Health & Beauty
Battery charged, horn and light works, but scooter will not move
Is the brake engaged? That's the lever at the back. Needs to be in drive position. if yes then it could be the Wig-Wag control. Are there any flash code errors showing? check your user manual in trouble shooting section.
May 19, 2015 | Drive Medical Health & Beauty
DMA SCOOTER WONT MOVE ALTHOUGH BATTERY FULLY CHARGED
Are there any fault codes, flashing light. Check your user manual in the trouble shooting guide.
Have you disconnected charger from scooter as it will not move if it is still connected to scooter.
Apr 18, 2015 | Health & Beauty
Why my power windows,dome lights,dont work plus car wont start
ok a lot not said here trouble shooting time. does the battery have a full charge "no" put a charge on it. battery wont charge and still wont do a thing dead battery get another one. ok battery charged and all works undo the positive cable on battery, if it still runs "good" if not alternator is bad. hope this helps not much to go on
Sep 09, 2014 | 2004 Ford Explorer XLT
MY BLUE TOOTH JUST STOPPED CHARGING IS THERE A WAY TO TROUBLE SHOOT THIS ISSUE
If the red charging light comes on when you plug it in and your battery isn't charging, you may need to replace your battery. If the light does not come on, it may be your charging port or your charger is bad. Here is how to replace the battery if you need to.
Oct 18, 2013 | LG HBS-700 Bluetooth Headset
Can't light pilot light on hot water service. Gas to property is connected as the gas stove works.
There should be a trouble shoot guide on the hot water tank. I have had to do this many times. You just need to read the trouble shooting guide & be very careful. I hope this works for you.
D :)
Feb 01, 2013 | Water Heaters
Burner lights and then goes out almost immediately
http://www.coleman.com/coleman/images/pdf/2300-700.pdf
Trouble shooting guide
Mar 14, 2009 | Coleman Hot Water On Demand
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Panasonic ER 153 Hair Trimmer Logo
23 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
