Question about Intex Krystal Clear Saltwater System Pool Chlorinator 54601e
System keeps alarming low pump flow yet flow is excellent with a new filter pump in place...how do i stop this alarm?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intex Master
  • 1,448 Answers
Is pump hooked up correctly? if so are filters clean? try running without filter cartridges in to see if more flow otherwise need more info
Posted on Jun 10, 2014
Yamaha 115 4 stroke alarm sounds when boat is in neutral. forward or reverse no alarm. oil is good and water out of the spout.
Which alarm is sounding? Oil or overheating? You need to figure this out first! ... Is the water coming out of the spout high pressure or can you hold your finger over it and stop the flow? If you can stop the flow, you have a bad water pump impeller. If not... you are probably getting good water pressure. If your oil tank is full, the low level sensor is dirty or bad..this will cause the alarm..Fix each of these and repost.
Jun 06, 2017 | Yamaha Boating
Why do i keep getting the low pump flow alarm?
are filters clean? if so check to see if impeller on pump is plugged sometimes hair and debris get caught in it
May 15, 2014 | Intex Krystal Clear Saltwater System Pool...
Why does my new intex saltwater system keep alarming low pump flow even after i connected a new filter pump, checked the flow sensor and cleaned the titanium
are your filters clean? try running without cartridges if it still errors out sounds like something is caught in the pump impeller
May 09, 2014 | Intex Krystal Clear Saltwater System Pool...
My system keeps flashing the 90 code indicating low water flow. My pool is full. What's wrong and how do I get the system to run normal? I just set the pool up and it has flash this cood from the...
Most low flow alarms are caused by the pump stopping before the chlorinator cycle ends. You must set the chlorinator hrs between the pump cycle. Start and set your pump cycle, wait at least15 to 30 minutes and then set you chlorinator hrs and make sure to it completes it's cycle at least 15 to 30 minutes before the pump cycle ends, If your pump turns off before the chlorinator cycle ends, you will get a low flow alarm......
Hope this helps, if it does, please rate...
Jul 25, 2011 | Intex Automatic Salt Water System for ...
Bought saltwater system last year ~ loved it!!! This summer the system continues to say, "low flow" and now the water is almost green???? Help!!!
Keep in mind, as soon as the system detects low flow, it turns the electrolytic cells off to prevent from burning them up.. If you have good flow and still get this alarm, check the flow sensor for dirty, stuck, defective or broken. See picture below..
Jul 11, 2011 | Intex Automatic Salt Water System for ...
Low flow keeps alarming
the manual doesn't tell u but the obvious solution is debris trapped in the filter that water flows from the pool to the pump. The one screwed into the pool liner. Unscrew the Blue cover , the one on the inside of the pool, and u will be surprised how much junk gets trapped in there, clean it out once and week and after vacuuming the pool
Jun 04, 2011 | Intex '10 Saltwater System Pool...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
The low flow alarm goes off
Check ALL sensors i can almost guarantee that it will be a faulty sensor.
May 26, 2010 | Intex 2000 GPH Filter Pump and Chlorinator...
Hi my a 160 starts then stops after about 10 seconds in this time it is unresponsive to the throttle have replaced key fob batteries although the lights flash the central locking doesnt work Cheers
Is it an aftermarket alarm/starting system? If so it may be burnt out. Without the right bosch relays to hold the locks down for 3 seconds the sytem will burn out trying to lock and unlock due to the air pump sytem. They might have also messed with the stock alarm system if you have it on your model which would compound the problem. If the car starts at all I would look at replacing the coil and coil wires as they are some of the biggest contributors to poorly running MB's. Then I would check the fuel pressure, maybe replace the fuel filter and check valve as they can keep fuel pressure low. After that might be a bad ignition switch which I doubt but anything is possible. If you also have an aftermarket radio it is tied into the stock alarm and that may not help your issues either. Hope I have given you a good place to start.
Jul 16, 2009 | 1993 Mercedes-Benz 190
Intex Krystal Clear Saltwater System Pool Chlorinator 54601e Logo
103 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
