Question about GE WWSE5240G
Lid switch how the heck do i get the washer apart on the model #22422100 to replace the lid switch?
  • 784 Answers
AP3968471 made by GE for your WWSE5240G. around 13 bucks.
Posted on Jul 04, 2009
  • GE Master
  • 3,361 Answers
Your model number is incomplete.
Posted on Jun 22, 2009
My Whirlpool washer won't spin and drain
First test if it is a problem with the lid switch. There are many YouTube videos on how to take apart the control panel and test the pins with a multimeter. On my washer, the lid switch passed the multimeter test but I did my test below and determined it was still the lid switch that was the problem.
When it gets to the point where the washer is supposed to drain and then spin-rinse but doesn't do anything, open the lid and push down on the lid switch lever with a small solid stick (chopstick, screwdriver, etc..) where the lid switch pin would normally push down on until you hear a click. If it suddenly drains, then the lid switch needs to be replaced. If you're lucky, it's a $6 part on ebay and 15 minutes of your time. If nothing happens, then find the YouTube video on testing the lid switch with a multimeter.
Jul 19, 2013 | Washing Machines
I need a washing machine manual for a Kenmore top loader, model number 22422100
Please check your model number. Kenmore washers have a 3 digit prefix followed by another 8 digits. If your full model number is 110.22422100, then Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/12008/KENMORE-Residential-Washers-L0407343?brand_name_search=110.22422100 . This is a generic manual for all Kenmore one-speed automatic washers. A copy of the descriptions of the washer settings is available here: http://www.managemylife.com/mmh/owner_manuals/15224/KENMORE-Residential-Washers-L0305156?brand_name_search=110.22422100 .
I hope this helps. If your washer has a different prefix, please add a comment with the prefix. I'll try to find manual for the correct model.
Jan 22, 2012 | Kenmore Washing Machines
The contact button (part where you put the door down to make the washer start to agitate) something came apart....washer is filled with water and now won't go. The part came out.
you broke the lid switch,send the full model number located under the lid,lift the lid up,follow the lid to the bottom and look right under it and you'll see the model number,it will start with like 110.
Aug 30, 2011 | Kenmore 22422 Top Load Washer
What is a code E2
kds e2 means lid switch is not being engaged .remove rear top cover .2 phillips screws .3 snap clips use flat blade screw driver to pop cover .look at rear of lid (door) right side plastic arm part of lid snaped off replace lid part xqb5526f.1.3-3 check saftey switch manually over ride switch as a test .if machine spins change lid if switch broken as well change both .switch # xqb550.1.6
Aug 10, 2010 | Avanti Top Load Washer W797
How to relpace lid switch on whirlpool washer model number lsr5101lq0
Good day,
Here is a tutorial on replacing the lid switch. Their position and installation will vary on certain models but it will be easily understood once the cabinet is apart.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Apr 27, 2010 | Whirlpool Washing Machines
Lid Switch
HI, The part# is 3949238. There are two ways to replace this switch. The easiest is to remove the two screws holding the lid switch. Pull the switch out enough that you can clip the wires at the switch. Cut the harness off of the new switch leaving enough wire to put wire nuts on connecting them together.
The other way to change the switch is to remove the cabinet. Here is how:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can see the lid switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Can't figure out how to get the washer apart to put in the lid switch.
If this is a Whirlpool made machine (which includes Sears Kenmore), there's a video here showing how to get the cabinet off for different models.
Apr 25, 2009 | Washing Machines
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
GE WWSE5240G Logo
222 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
