Question about Maytag EPIC MFW9700S Front Load Washer
How do I clean the drain on my front loader to rid the sewer smell?
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: My Maytag MFW9600 front-loader makes
You will need to clean your washer out with this cleaner... The detergent and slime between the tubs mildew and a mold grows. Follow the instructions on the bag and use all 3 tabs to start. You need to change to a good detergent. Use a detergent with oxyclean or some type of oxgenated ingredeient.
You can find this cleaner at HomeDepot or Lowes
http://www.affresh.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 10, 2010
  • 113 Answers
SOURCE: the inside of my maytag epic front loader washing
Buy some Affresh cleaner. You can find this at Home Depot. It should clean gookus from front boot. Also, take a dry rag and `clean the boot area of mold and mildew. I know some of my customers just leave the door open overnight to let it air our.
Posted on Sep 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: we have a used front loader maytag washer...there
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Posted on Oct 12, 2010
I get a very strong smell from my maytag atlantis washer. it smells like the sewer. how do i remove that smell?
Confirm that the sewer trap is working. The sewer trap for a washer is the pipe connection where the washer drain hose connects.
It would not be likely that the trap is a problem. Sewer gas and mold can smell similar. Smell around the hose connection. Some older homes just simply had a drain to the outside
26162560-vtficdakbbyhbpkipaftpy0h-4-0.png Next this machine is a top loader and if it is being used several times a week the problem is likely around the tub on top. Mold will form in the tub under the basket if it is not run weekly. Normal wash cycle in a top loader should keep under the basket clear. If a week or so occurs between use then the problem can be under the basket at the bottom of the tub. Use bleach, vinegar, or baking soda in moderation to clear.
It is more likely that the problem is around the top of the top. this requires opening the top and swinging it back to get access. Make sure power is removed before attempting.
Cleaning a little bleach, soap and water.
26162560-vtficdakbbyhbpkipaftpy0h-4-9.jpg this helps?
Apr 13, 2016 | Maytag Washing Machines
Sewer smell coming from sink when water runs into drain
is there a trap in the sink drain just under the sink
if not put one in
a trap holds water in a bend so sewer gases dont come up through the drain
Nov 20, 2013 | Dishwashers
I have a Whirlpool top load washing machine. lately it really smells. I ran several cycles with bleach to try to get rid of the smell...but it doesnt help. Help...my house smells like a sewer.
Jan 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Help, my dryer stinks like sewer smell when running, my husband just vacuumed out all of the vents, and it still smells foul!
This is common for front loader washers. They make cleaner that you run through your washer once or twice a year to correct this problem. Take a look at this page there is a link to where you can buy some of the cleaner under the section called clean washer http://www.appliance-repair-it.com/dryer-maintenance.html
Oct 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have had my duet for about 5 years. I thought
The problem is commonly caused by debris building up in the drain pump. Over time it sours and begins to smell. The following link explains how to access the drain pump and clean it:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
There are several other factors that can also contribute to front loader odors. The following link explains a things to look for and try:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the information provided and let me know if you have any questions. I hope you find this information helpful.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When machine pumps out the smell comes through the sink
All plumbing drains whether under a sink or the stand pipe drain, for a washer, are required by LAW to have a trap to prevent the sewer gases from entering a home.
Sewer gases are dangerous in many ways, not the least of which is the terrible smell. Sewer gas can build up and if allowed to accumulate near an appliance that operates on gas (LP or natural) can combust and cause a fire and/or an explosion.
Yes, if you can do the installation youself, do it ASAP, or contact a licensed plumber and have installed a proper drain trap for the sink and also make sure the drain that the washer is draining into, also has a trap in it.
This will have a profound impact on the smell and will help alleviate foul odors from your sewer lines.
Hope you found this Very Helpful and best regards!
Sep 22, 2009 | Whirlpool AWM5145/2 Front Load Washer
How do I get rid of the stinky smell of my front loader?
The smell comes from your front rubber boot you must replace it toget rid of the smell.The water collects in the inner part of the boot and and sits there till it smells hope i helped
Sep 20, 2009 | Kenmore Elite 45986 Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
Strong meldew smell from washer
Please take a look at the following link and see if you are following all the steps. Front Loaders are notorious for smelling this way , but there are things you can do to minimize the problem. I have owned a front loader for 8 years now and have never had a problem by following this advice.
http://www.fixya.com/support/r513372-front_loader_mildew_odor
May 16, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytag EPIC MFW9700S Front Load Washer Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
