My window unit is not blowing cold air. Ive used it a handful of times and it never got cold. How do i fix this?
  • 400 Answers
There are very many possible causes. You do not indicate your model number, but many units take a few minutes before the compressor comes on. If the compressor is not coming on (a low rumble sound, NOT the fan), you'll get no cooling. If the compressor is coming on, and you still get no cooling, it is likely your unit needs a recharge. Things to check: Is the thermostat set lower than the room temperature? Is the unit set to "fan only"? I hope this helps lead you to the problem and a solution.
Posted on May 09, 2014
SOURCE: comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
Posted on Jun 08, 2008
motor1258
  • 6674 Answers
SOURCE: No Cold Air
Have you removed inside filters and cleaned them? have you gone up and removed the cover to see if fins are dirty, or perhaps wasps etc. Does fan only have one speed on thermostat. Does fan run faster on fan only operation? Is it tripping your breaker at all?
Posted on Aug 16, 2008
  • 24 Answers
SOURCE: not blowing cold air, do u recharge this unit?
only after you find a leak. first u have to make sure if the compressor is running at all. condenser side spinning. if compressor is not working it will blow hot air if the condenser is dirty or blocked but then u would get a minute or two of cold air then hot. you have to determine its empty or what else might be the cause before you start dumping in freon.
Posted on May 28, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
Everstar portable A/C unit MPM1-10CR-BB6 not getting cold
It seems low refrigerant issue need to refill refrigerant
Jul 26, 2016 | Heating & Cooling
Why is my brisk air duo therm rv ac freezing up on the inside.
Where you see frost all the time, wait for unit to thaw and start cooling again and carefully slide hand up in that hole and see if you can feel cool air leaking in from divider that separates cool and return air, that will cause freeze-ups as well. Use foil tape if necessary to stop any cool air coming in to return air from around divider. Also, if you have any diffusers closed, (on ducted system in ceiling) or partially closed, open them all up full flow. If you restrict the cold air from coming out too much, it can also cause freeze up. One more thing, take cover off where cool air box is and double check that something isn't restricting the flow of cold in to the duct work if it has ducted system.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Not blowing cold air
unplugged the unit, kept the doors closed about 10 to 12 hours plugged back in and in about 2 hours started blowing cold air into freezer another 4 hours was blowing cold air into refrigerator and continuily got back to the themostat settings,about 1 day. no food was lost because the doors were closed still keeping it cold. i think the fan in the freezer was frozen with ice,but could access it, not the main fan in the back the unit by the compressor,that was running fine. so basically i defrosted the freezer fan by unplugging it. this is the 2nd time in 4 years ive done this, well it beats spending 1000-1500 dollars to replace it TRY IT I HOPE IT WORKS FOR YOU BEFORE YOU CALL FOR SERVICE,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Vents Not Blowing Air
yes winter is approaching ....if yer doing this yourself it will be detailed my friend ...remove the control unit itself and visually look for vacuum lines cracks or lever corrosion this works on vacuum and a steel line it may be slipping or bent follow the cable from the heater down or its possible you have a blockage in the vent Ive seen it a hundred times
Aug 25, 2009 | 1998 Chevrolet Monte Carlo
Problem with the Air conditioning unit 2005 toyota avensis
if its cold at 1 location all the time its probably got its gas maybe theres a vent not opening or a duct that has come adrift under dash,if its not cold in general you may need to get an AC guy to look at the fault but keep looking if you think something is simple to fix
Aug 16, 2009 | 2005 Toyota Avalon
Panasonic air con unit is not blowing cold air out.
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Window ac unit is not blowing cold air
Jun 07, 2009 | Whirlpool ACQ189XM Air Conditioner
Cooling problem
Check your unit for dust buildup or blocked filters. Clean as required.
Jun 14, 2007 | Fujitsu 12C1 Air Conditioner
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
