How i open the machine's door because it is lock
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Usual cause is a faulty interlock/ wiring.
to open the door, disconnect the machine from the mains, remove the lid and then put your hand down the right hand side of the door between the door and the drum. you should feel the locking mechanism, there is a manual release, its just a case of feeling for it and its usually a pull
Posted on May 31, 2014
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Sep 16, 2010 | Whirlpool Washing Machines
My machine wont start ,unless i really have to slam the door real
Either the switch striker/actuator on the door is worn or the door lock/switch assembly on the right side of the door opening is faulty. It is recommended to replace both parts when one is faulty or worn. The door lock/switch assembly is part number 1094190 and costs about $55. The switch striker/actuator is part number 906446 and costs about $5.
Door Lock/Switch Replacement Procedure
  • Unplug the machine.
  • Open the machine's door.
  • Locate the retainer spring of the seal boot retaining hoop at the bottom of the door opening.
  • Stretch the retainer spring apart then remove the retaining hoop.
  • Ease the edge of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot. It will cause water to leak out of the machine.
  • Remove the three screws securing the door lock/switch assembly to the front panel.
  • Slightly lift the door lock/switch assembly, pull it away from the front panel then pull it out of the machine.
  • Disconnect the wiring harness and connect the new door lock/switch assembly.
  • Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code du
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Jul 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Door lock is locked but door is open
take the kickplate of the machine of and put your hand iside by the door lock , fill a round tab there just pull and the door is going to unlock
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
