Question about Sony Prs-t1 Pearl Red 6" Ebook Reader With Wi-fi
Reader does not keep picture of the correct book being read.
It will keep the page of the book being read, but if the reader is completely turned off, it will not. When turning reader back on, I need to look up the book I was reading and figure out what page I was on when I closed the reader.
praky16
  • 744 Answers
SOURCE: my psp wont read the games
hi..
Have you upgraded the firmware? if not go to sony's site and download the firmware and from there load it to your memory stick and update. this should resolve the issue. you can also update the system if you are wireless and can get internet access on your psp. if this does not work get in toutch with sony thay will advise you wether it can be fixed or if you need a new on..
thank u
rate me
Posted on Jul 27, 2009
  • 11800 Answers
SOURCE: Cannot read CDs, can read DVDs
If it would have been a soft problem it wouldn't have worked at all, the driver is for the unit, not just for a function. Most likely it's a HW problem: either the laser died or the lens is dirty - try cleaning it.
Btw if your unit can't read cd's how those morons at the shop expect that you could reinstall (or repair) your Windows?
Test your unit your self: take it out, put it in another laptop (or in an external case and attach it to another pc and check there. If it's dead then replace it with a new one - preferably a dvd-writer of any mark.
Posted on Sep 12, 2009
ani24das
  • 89 Answers
SOURCE: My sony reader looses battery power while turned
If you will not use the Reader for 1 week, the battery will be drained. This is normal operation. But, if the Reader is showing only 1battery bar within less than a week even after charging it fully, there might be an issue occcured with the Reader. In that case, please chekc whether you've charged the Reader by connetcing the Reader to a USB version 2.0 port of the Computer.
If the issue still occurrs, please try resetting the Reader by pressing the RESET button using a sharp-pointed object.
Above mentioned steps should resolve the issue. If the issue still persists, service of the Reader may required.
Posted on Jan 19, 2010
ani24das
  • 89 Answers
SOURCE: My sony reader is frozen. I cvharged it
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred.
Please perform the below mentioned steps and check whether it helps.
Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure.
2. Perform a soft reset. Just press the RESET button using a sharp-pointed object
3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again.
5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding.
6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset.
7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off.
* It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E.
8. Once the Reader has sufficient charge, perform these troubleshooting steps again.
9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status:
* You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged.
* It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
http://eservice.sony.com
Posted on Jan 21, 2010
SOURCE: dvd player will no longer read discs
discs is read but video is not cominig
Posted on Feb 13, 2010
How do I know if I have Kindle in the cloud? And how do I get there from my tablet
Kindle has one of the best help sites in the business. Has already been answered on Fixya, bottom link.
Kindle Cloud Reader - 7 tips and facts to know - Ebook Friendly
https://ebookfriendly.com/kindle-cloud-reader-tips-facts/
Feb 19, 2017 - Kindle Cloud Reader - tips, facts, and things to know ... If you don't have a Kindle e-reader, a tablet or a smartphone, you can still access your ...
Amazon.ca Help: Organize Your Kindle Content with Cloud Collections
https://www.amazon.ca/gp/help/customer/display.html?nodeId=201733490 Cloud Collections on Kindle E-Readers ... After a collection is deleted, the items that were in it appear on the Home screen if you sort items by Collections.
Amazon.com Help: Sync and Download Content to Your Kindle Fire
https://www.amazon.com/gp/help/customer/display.html?nodeId=201730090 Digital content purchased from Amazon is saved to your content library in the Cloud. In order to download content, make sure your Kindle Fire is connected ...
How to read Kindle Books with Kindle Cloud Reader - OverDrive ' Help
https://help.overdrive.com/.../1481605-how-to-read-kindle-books-with-kindle-cloud-... Mar 24, 2017 - The Amazon Kindle Cloud Reader is a web app that allows you to read Kindle Books in any ... That means if you make a note in a book you're reading on the Kindle Cloud Reader, you can look at it later on your Kindle or Kindle reading app, as long as you have internet access. ... GET TO KNOW US.
Using Amazon's "Manage Your Kindle" Page ' Managing Your Books ...
www.informit.com > Articles Feb 12, 2014 - If you have multiple Kindle devices, the Manage Your Kindle Page is ... Cloud to your device, can be accomplished directly on your Kindle Fire.
How do I know if I have Kindle in the cloud? And how do I - Fixya
www.fixya.com/support/t26666464-know_kindle_in_cloud_get_from_tablet 36 mins ago - Kindle has one of the best help sites available! How to transfer books from Cloud Reader to my actual Kindle ... Can read on Kindle Cloud Reader.
How do know if have Kindle in the cloud Google Search
Jul 17, 2017 | Tablets & eReaders
When i turn the page on the sony ready touch I can still see the last page under the next page. Has this happened to anyone else?
Hi patsyhodgins!
At certain point this "goshting" you see its normal operation because of the type of screen (E-Ink) but if you get words mixed or its too difficul to read, you can try a reset:
Note: This will not affect your ebooks:
1. Disconnect the reader from the computer
2. Power off you reader
3. Hit the reset at the bottom for 3 seconds
4. Power on you reader
5. The screen will blink and will display "Opening Book", let the reader load your books
See if the problem persist, if so, you can try a hard reset, make sure the reader is fully charged.
Note: This will delete all content from you reader, I recommend you to back uo your data before proceed:
1. Power off the Reader.
2. Press the RESET button.
3. Power ON the Reader.
4. When the screen shows "Opening book..." , press and hold at the same time the "Page Back" button and the Volume + at the bottom until the "Reset All" appears on the screen
If none of the steps above work, then contact Sony to get the screen repaired.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 17, 2011 | Sony Reader Touch PRS-600
The device has been working fine for well over a year now but recently it seems to freak out in the middle of a book, get confused and go back to the home menu. Now, more worringly I now cannot start...
Hi!
Probably sometinng got corrupted on the book, you can try a soft reset to see if the issue is fixed, if not you will need to do a hard reset, this will set the reader to factory settings and remove all data:
Note: Make sure the reader is at least half charged.
To Soft Reset:
1. With the reader disconnected from the computer, hit the reset at the bottom of the reader for 3 secons
2. Slide the power switch, the screen will blink and will show "Opening Book". Allow the reader to load and see if the problem still persist
To Hard Reset:
1. Hit the reset button at the bottom of the reader for 3 secons
2. While the reader shows "Opening Book" press and hold at the same time the number zero "0" and the down arrow on the directional buttons until "Reset All" appears
3. The reader wil laskyou to press the number 5 to proceed
4 Reader will go off, now you can turn it on and allow it to load this time.
GoodLuck!
eBookBoy
Jul 11, 2011 | Sony Reader Pocket PRS-300
Library books show "protected page"
This error may happen when you have eBooks that you borrowed from the library in both Adobe DRM-protected ePub and PDF formats on the Reader digital book at the same time. Follow these steps to correct this issue:
1. Delete all borrwed books from the Reader digital book.
2. Verify that all borrowed books are in the same format (either ePub or PDF) before transferring them back to your Reader digital book.
eBookBoy
Jul 10, 2011 | Sony Reader Touch PRS-600
I have an ereader that will not let me read pass page 66 in the book it says error. How do correct this error and continue reading? PW
are your books samples? or full version? most samples are a few pages... open a book on the reader tap the bottom of page if its a touch screen to see how many pages are in the book drag your finger across to see if it by pass page 66........open up settings to make sure your book is not limited (pages) if so disable it
May 15, 2011 | Computers & Internet
How do I get books on to this system?
If i understand correctly - you want to use phot frame as your ebook reader. You can't, it wont read any known ebook formats... unless...
you can try getting every page saved as .jpg file and then watch it as pictures.
Mar 06, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Hi! i have a problem with my prs 300 sony reader. my reader opens the page of a book that i am reading but when i open another book the page is stuck with the old page that i am reading. sometimes the page...
Depending on what the file type is you can always try another application to open up the book for example if it is a pdf format you can always try using adobe reader. However, I believe the issue here is that there is a page that might have been corrupted or unviewable depending on the situation you may want to consult whoever you got the book from in case you had purchased this book to see if you can maybe get another copy.
Jul 14, 2017 | Sony Reader Pocket PRS-300
How do I change Microsoft Reader as default?
http://www.microsoft.com/reader/info/tips/nolonger.aspx
Here's how to fix the problem:
  1. Shut down Microsoft Reader:
    a. From the Start Menu, tap "Settings"
    b. Select the System tab.
    c. Select the Memory icon.
    d. Tap the Running Program tab.
    e. Highlight Microsoft Reader on the Running Program list.
    f. Tap the Stop button.
  2. Tap OK.
  3. Start File Explorer
  4. Navigate to My Documents/Annotations
  5. Select and delete the .EBO file for the problem title. The correct .EBO file is the file that begins with the eBook title. If more than one .EBO file exists for the problem title, select and delete each one.
  6. Start Microsoft Reader again.
  7. Open the eBook. Let the device remain turned on, allowing Microsoft Reader to repaginate until it completes. This process should not take more than a few minutes. Microsoft Reader needs to perform this operation just once for each eBook.
How do I know if Reader is still handling background pagination on the title?
  1. Open the eBook in question.
  2. Begin reading the content.
  3. On the bottom of the Reader page, tap and hold the page number for a couple of seconds — then release it. The Riffle Control should be displayed: its appearance may take a second or two.
  4. The Riffle Control shows you where you are in the eBook. The leftmost number is the first page of the eBook; the rightmost number is the last page of the eBook. If the rightmost number is displayed in red, Microsoft Reader is not done with background pagination. If the rightmost number is displayed in black, Reader has completed pagination.
Jul 26, 2010 | Adobe Computers & Internet
My Sony PRS505 ereader has an "empty" book
The formats of the books downloaded from the Waterstones website might not be supportd by the Sony Reader. Please transfer the compatible files to the Reader. To know about the supported files formats for the PRS505 Reader, click here.
Apr 17, 2009 | Sony E-reader Portable E-book MP3 Player
Sony Prs-t1 Pearl Red 6" Ebook Reader With Wi-fi Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
