Question about Baby Lock Sewing Machines
How to clean wiper sensor on enterprise - Baby Lock Sewing Machines
  • 2 more comments
  • Hi Nancy Early, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Nancy Early
    Nancy Early May 27, 2014
    So sorry for the long delay! Now, everytime the machine changes colors it won't cut the thread and I have to do it manually. It says, "Sensor error." I've taken the bobbin area apart 100 times and cleaned it and have even cleaned behind the needles. I must be crazy! Can't semm to fix the problem. Do you have any suggestions? THANKS!
  • since the machine is showing a sensor error, it probably good idea to have the machine checked to see if there is a problem with the computer part of the machine.
  • Nancy Early
    Nancy Early May 28, 2014
    Thanks! I'm taking it Friday.
    Sergeant:
  • Baby Lock Expert
  • 454 Answers
Cutter blade needs replacement. Sensor is likely fine and is not located in the bobbin case area.
Sensor is telling you there is a cutter error. More than likely need a new cutter. Easy enough.
Cheers,
Kelly
San Diego, CA
Posted on Jun 16, 2014
How do I get the wiper off so I can put my new one on?
What is a "wiper" on a sewing machine? That's a term not common when referring to a sewing machine.
Mar 15, 2016 | Sewing Machines
How do you fix a thread on a sensor. My machine has been in the shop and has the same problem after using is for 45 minutes. It just makes the computer noise and will not sew.
It sounds like you are getting a message that the thread is broke. There are often two sensors for tread problems. The upper thread sensor is usually on the check spring. When the check spring fails to move up and down the sensor indicates the upper thread is broken. This can be confused with lint. It is difficult to see the check spring without taking apart the machine. It is above the needle clamp and below the take up lever where the thread goes from down to up.
In the bobbin area are optical senders and receivers that sense low bobbin thread, These are confused when their is lint blocking the sensors. This can be cleaned with a small brush. Rotate the hook and clean in the hole that the sensors are shining through. That said you can also have bad sensors or loose wires or a computer chip problem that will give you error messages. The most challenging ones are those that work some of the time. When you take it in and it works they service person thinks the problem was solved with cleaning. Take it back if cleaning does not help.
Mar 22, 2015 | PfaFF Sewing Machines
Sailrite Manual
Call or email Sailrite, they make the machine so one would guess they have instruction manuals...
Sailrite Enterprises, Inc.
2390 East 100 South
Columbia City, IN 46725
Store Hours
Monday - Friday: 8am - 5pm EST/EDT
800.348.2769 (toll free)
260.244.4647 (local)
260.818.2005 (fax)
sailrite@sailrite.com
Apr 03, 2014 | Brother CS6000i Computerized Sewing...
Little power from foot pedal on used singer 6233
Ok I am just guessing here, as a lad i use to use my mums Singer, the peddle was intermittent & scratchy, knowing what I know now about variable speed motors I an guessing the wiper is not making contact with the carbon,
If you can take the cover off, give it a Light dusting from a air compressor, your only blowing the dust away, not to clean, Then spray with ISOPROPNOL. READ INSTRUCTIONS BEFORE USE.
Oct 04, 2017 | Sewing Machines
Does not recognize when bobbin thread has run out
Clean out the bobbin area. Try to determine where you sensor is and used canned air to clean that. Hopefully it's just a dirty sensor and not a bad one.
Good luck
Sep 08, 2012 | PfaFF Sewing Machines
Check Lower Thread message come up repeatedly while sewing and embroidering. Thread is not broken. Why is this happening?
This is usually because there's fluff in the optical sensor that's fixed to the bobbin door, or alot of fluff in the rotary hook. Remove the bobbin case and give the hook a good brush-out with the supplied brush and also get a cotton bud and gently clean the lens on the lower thread sensor. This is a black 'box' attached to the bobbin door ... if you look carefully, you'll see a small lens and an opening next to it; make sure the lens is clean and the whole area is free of fluff. If it's still giving a lower thread breakage indication (not an upper thread breakage - this is a different sensor), it may be a faulty sensor or the sensor may have become disconnected from the main processor board. Get it checked-out by a qualified Bernina service agent.
Nov 06, 2011 | Bernina Artista 180
Babylock espire bobbin sensor not working
This is normally caused by lint in the bobbin area, the lint blocks the sensor causing it to be blind. Try cleaning the area and see if that helps.
May 28, 2010 | Yamata FY101-1A
Huskvarna Viking quilters 850 I keep getting
it is a problem your tech can fix, ( should have been done when he had the covers off) but take it back in and tell him to adjust the sensor on the cutter so it doesn't rub and to clean the sensor. this will fix the problem
Oct 20, 2009 | Husqvarna Viking 1
Wiper error occuring between thread sequence.
wiper error can come from the needle threader not working right, the cutter not working right or the picker not working right, i would recommend taking this to a dealer for service because setting the picker is easy but you have to be in the service program of the machine
Apr 27, 2009 | Husqvarna Designer I
Wiper error
What is the specific error that you are getting? Tell me exactly what the machine displays.
I assume the wiper you refer to is the fetcher. It is the long piece that reaches from left to right and pulls the thread back to the blade. The left end of the fetcher should be going all the way to the gray hook cover body when it is fully retracted. If the left end doesn't go all the way to the side, it may be hanging on the thread brake, the little brass piece with velcro on the back.
First, just tell me exactly what the error is.
Apr 08, 2009 | Husqvarna Designer I
Sewing Machines Logo
157 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
