Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Water leaking from stacker unit
I have a whirlpool thin twin stacked washer/dryer and the other day i noticed water leaking out of what appears to be the pump,
seems to be where the shaft passes through the plastic case.
are these fixable??? gasket/o-ring blown?? is it worth fixing?
  • Whirlpool Master
  • 3,361 Answers
No parts are replaceable within the pump. Buy a new pump.
Posted on Jun 22, 2009
Thin Twin has a slow water drip when not running
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Oct 28, 2012 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Twin Thin - Water Leak
It sounds like you have a bad pump. If the bottom of the washer is not solid just lean it back and take the pump off. There should be a streak of water stains on the inside of the pump if it is bad.
Nov 17, 2008 | Whirlpool LTE6234D Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Thin Twin Fills up with water and then Hums!!!!!! Dryer works fi
this unit has no belt,,your motor coupling broke,,i can walk you though,,post question how to change motor coupling,,and its not your motor
Nov 10, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
254 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
