Question about HP Officejet 5510 All-In-One Thermal Printer
HP 5510 acts like printing but no ink
I have 2 brand new cartridges - I've tried all the troubleshooting tips, I've tried printing test pages but as per problem it acts like it's printing but no ink. I've manually cleaned the ink cartridge heads and confirmed that ink is running - all to no end.
tips?
    Guru:
  • 224 Answers
See if you have tried cleaning the cartridges and you still face this issue try with diffrent cartridges and if again you still face this issue then its your printer that needs replacement,since i work for HP.
Tell ya what call in to hp at 1800-474-6836 and ask for an upgrade where you will get 50% atleast off on the upgraded printer and you will get a high end and also then you can extend your warranty for 3 years so if you face any hardware or software issues then your printer cost will be covered by hp and you will get a replacement printer free of cost if its a hardware issue and software assistance free of cost,Think about it and then call us up
Posted on Jun 23, 2009
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
I got 3 months ago message on hp officejet j4580 display: Print cartridge problem: [Tri-Colour]. Refer to device documentation to troubleshoot. Today while printing a document, i noticed printing with...
You must be using HP60.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4580 is pretty new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Hp 5510 printer/copier/fax/scanner will not print docs. The paper goes through but nothing is on the paper. Tried to print test page, same result. I've checked the cartridge - not empty. Haven't used the...
It sounds like the jets on your cartridge is plugged. I have unplugged some cartridges by soaking the jets in alcohol. I pour some alcohol in a shallow dish and set the cartridge in it with printing jets down. Leave it for 5-10 minutes. If the jets start to unclog you will see the ink discolor the alcohol.
Be careful when wiping off the ink jets so you don't damage them. Use a soft cloth. Try the cartridge and see if it prints. If you need to soak it longer.
Jul 13, 2010 | HP Officejet 5510 All-In-One Thermal...
Troubleshooting a HP Officejet 5610 All-In-One InkJet Printer. Installed new ink cartridge but it's still acting like its out of ink ie, spotty printing. Suggestions?
50% or stronger isopropyl works well as a solvent, 91% dries very quickly. Try cleaning both the contact-film surface of the ink cartridge and the print-head (carriage, actually) in the printer with a lint-free cloth or swab and solvent (swabs reach to the carriage contacts better) CAREFULLY. Clean the print head on the cartridge itself by pressing straight on, not rubbing back and forth, with a lint-free cloth and solvent. Use the HP print head cleaner program first, then check alignment with HP's program, then print a test page. Is this not exactly what the help file on maintenance tells you?
Oct 23, 2009 | HP Officejet 5610 All-In-One InkJet...
I am receiving the ?Print cartridge problem-[Tri-Color] refer to device doc. to troubleshoot.? Error message on my Hp j4580. There is no help in doc and nothing I?ve tried (cleaning etc.)works. Should I...
I had the same problem. I called hp and spent an hour running through the troubleshooting things that I'd already done. They ended up sending me a new ink cartridge, and surprisingly, it worked. For some reason, the printer refused to recognize a nearly full ink cartridge. Go figure. It seems to be working for now, but it's a huge waste of ink and money. If you have the patience for it, call hp and see if they will replace your cartridges.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Acts like its printing but no ink on paper
Using HP Director, you should be able to check estimated ink levels by selecting Settings -> Print Settings -> Printer Toolbox and then clicking on the Estimated Ink Levels tab.
If the ink levels appear to be sufficient, on the printer control panel press Setup, 1, 4. This will generate a self-test report. If there is streaking of any of the 4 bars at the bottom of the page, the affected cartridge may need to be cleaned. If any of the bars are missing, the cartridge needs to be replaced.
To clean the cartridges, press Setup, 5, 1. This will print a page of patterns.
Mar 17, 2009 | HP Officejet 5510 All-In-One Thermal...
This is for an HP Photosmart 3310 all in one. The display shows message Ink System Failure Error 0xc18a0206. Tried the troubleshooting steps on HP website: remove ink cartridges, unplug printer from...
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
