Question about Gaggia Titanium Espresso Machine
My Gaggia Titanium screen is just Blank Squares. Help! ?
The Steam function still works, but the Digital screen is 'alive' but has squares over the top line, and it will not respond to any of the pushbuttons (including making coffee) Help!!
  • 1,511 Answers
The LCD screen has been damaged by an electrical charge, like a power surge. Always keep a Line Surge device attached for protection.
Posted on May 09, 2014
  • trine themsen
    trine themsen May 09, 2014
    If it was only the LCD screen that was damaged, I dont understand why teh steam still works (so boiler works) but it wont make a cup of coffee ??
  • 1089 Answers
SOURCE: gaggia syncrony compact is leaking. Removed top
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Posted on Jun 14, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Posted on Jun 19, 2009
  • 1089 Answers
SOURCE: Gaggia Titanium coffee maker leaking water
What color is the steam manifold? It is located under the black cover with the trough in back under the white tube. If its white or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand. But its going to have to be replaced.
If it is silver you probably have O-rings that need to be replaced. I would use the black O-rings, not the red. The red ones are a little smaller and can leak.
Posted on Dec 01, 2009
  • 109 Answers
SOURCE: Gaggia Titanium blocks on display screen
The main board has failed.
Sorry no quick fix for that one
Posted on Feb 22, 2010
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Steam in display unit - now only displays squares, no writing
not good you need to remove the display and dry it up and see if the contacts are clean and soldered do solder if its ok only clean it with contact cleaner for electronics
Mar 06, 2016 | Gaggia Titanium Espresso Machine
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
Aug 03, 2015 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Gaggia titanium 120volts
open steam valve and run water couple minuts on
Aug 26, 2009 | Gaggia Titanium Espresso Machine
Jun 18, 2009 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
191 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
