Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
Replacing sylinoid on john deer lt155 - John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
  • 11 Answers
SOURCE: have john deere lt155 in storage for 3 yrs won't
sounds like one of two things can wrong...
1) the magneito may have built up a fine layer of rust up between it and the fly wheel magnets.
*solution to this is to take some fine sandpaper (wet/dry will work) and sand the magnets on the flywheel and then carefully sand the two contact post's on the magneito that face the flywheel when it turns. after this you'll have to re-gap the magneito. you can use a good crisp buisness card to do this.
loosen up the two bolts holding down the magneito (dont take them out) so that the magneito will slide to flywheel when magnet comes around...place the buisness card on magneito post's surface so that it creats a bearer between it and the flywheel (you'll have to use both hands to do this) then while holding the buisness card in place turn flywheel (by hand) (its easy and safer to remove spark plug to do this) untill magneito automatically slips towards the flywheel magnet (dont remove card yet). tighen the bolts so that the magneito stays in place while you remove the buisness card slowly so as that you dont disturb the placement of flywheel to magneito... once you tighten the bolts the rest of way you in buisness
2) the pionts might need to be re-gapped or even replaced.
* they are located under the flywheel of mortor. you'll have to take it off to get this far..
i would try the magnneiot solution first.
Posted on Jun 25, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
e-Guru
  • 3917 Answers
SOURCE: we have a john deer rider lt155 runs great
If the engine starts to slow down and then stops all together, it is most likely "Seizing" up. The best way to check if this is the case is to try to start it when it has just stopped. If it will not crank or you can not pull the start rope it is because the clearance between the piston and the cylinder is too close. This is normally caused by the engine running out of oil at sometime in the past or the cooling of the engine has been interrupted by grass plugging the passages, the engine has over heated and the friction between the piston and the cylinder has caused metal on the piston and the cylinder to expand and transfer and bind the parts. If you can't pull it over and it is "frozen" and will not rotate it is cheaper to just buy a new engine in the long run. If it will pull over and doesn't run look for loose carburettor on the flange that bolts to the engine block or low compression as the reason.
Also when the engine quits you should check for spark before it cools down. If it doesn't have spark I would suspect the ignition coil. If it does have spark I would suspect that it is a fuel problem. Check the tank for debris and water. Water will look like blobs on the bottom of the tank. The most likely cause is the carburettor. I would remove it and take it apart for a good cleaning with curb cleaner. A rebuild kit should be used to put it back together. The electrical connection on the bottom of the curb is a fuel shutoff solenoid. It should have 12 volts when the key is in the run position. If it doesn't the fuel will be shut off to the curb. Sounds like you listed all the normal maintenance. Oil changes every 25 hrs. Air filters once a season or every 100 hrs, same with oil filter. Check your fuel cap and make sure that the vent is not clogged with debris. If you can't blow through it slightly, it is clogged and creates a vacuum in the tank after it runs for awhile, stalling the engine. You can test this first by just loosening the cap a bit and see if the problem goes away.
Let us know if you want something else please accept the solution.
Posted on Sep 21, 2010
SOURCE: Have John Deer LT155 that gives me problems starting
hi the kohler 15hp had problems with the hydraulic lifters hyperpumping with oil and not bleeding down thus holding open the valve. check out kohler.com on google also check out troubleshooting hydraulic lifters.com on google.
Posted on Oct 19, 2011
SOURCE: need wiring diagram for lt155 john deere riding
need wiring diagram for john deere lt 155
Posted on Jul 28, 2012
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
Manual for John Deer LT155 wiring an scymatics
I wish people would learn how to use GOOGLE!!!!
VERY FIRST THING ON A GOOGLE SEARCH, IN IMAGES!
john deere lt155 wiring diagram Google Search
Please be patient, the website below seems to be very slow.
John Deere LT155 Wiring Diagram
Jul 26, 2016 | Cars & Trucks
John Deere LT155 starting problem
check to see if your get power to the starter
Sep 09, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Need wiring diagram for lt155 john deere riding mower
Aug 26, 2010 | John Deere Garden
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
Good day.
Oct 14, 2009 | John Deere Garden
John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Sep 29, 2009 | Garden
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
21 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
