Question about Measuring Tools & Sensors
My dewalt 735 planer sometimes runs and sometimes it doesn't. Tried tightening the dustcover replaced circuit breaker and mini switch. What next?
  • 1,511 Answers
You did the usual things, but the problem seems to be at the plug or along the line itself. There is an open short and at times the conncetion may seem solid. Replace the cord.
Posted on May 09, 2014
3 Suggested Answers
radar001
  • 1051 Answers
SOURCE: the drive belt on a
The pully which quides the belt must be perfectly level in both the horizontal and vertical positions. Use a metal square to check alignement and adjust using adjustment screws.
Posted on Apr 25, 2011
  • 190 Answers
SOURCE: Can I get a paper manual for the 735 planer?
Got to:
www.servicenet.com.
You can order a replacement manual for the dw735 from them.
Hope this helps.
Posted on Apr 28, 2011
DeWalt 12 1/2 inch thickness planer 2012 15-ct 160357. The motor was changing speeds with no load and finally simply stopped. Does it need new brushes or possibly the reset switch is faulty.
IF THE UNIT DOES NOT RUN, CHECK TO SEE:
• if the unit is plugged in.
• if the dust shroud is properly in place.
• if the top cover is properly in place.
• if the circuit breaker needs to be reset
I would replace both brushes and ckt breaker.
https://www.ereplacementparts.com/dewalt-dw735-type-inch-planer-parts-c-1009_2664_2987.html
May 12, 2018 | The Computers & Internet
My Dewalt 735 planer won't turn on. I blew the house fuse a few times, it would start after I came out. Now it won't start at all and it's been a couple days
The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735.
Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check.
A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick.
I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time?
A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
Nov 23, 2015 | Dewalt Planer (DW734)
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
Dewalt 735 planer wont start
Power? circuit breaker? Plug? Owner's manual. Troubleshooting
Does the motor hum? if so you have something jamed in the planer cutter.
Feb 28, 2015 | Dewalt Tools & Hardware - Others
The planer trips its circuit breaker after only planing for two or three minutes
Check out the circuit breaker - they get old and trip too easily.
Jun 30, 2014 | Dewalt Planer (DW734)
The planer keeps tripping its own circuit breaker.
There is a wire that is shorting out some where on it.. I would start with the switch then go to the cord.. If that doesn't work, you'll need to take it a part and look for a striped or broken wire.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jay_17408fb1a2cad107
Aug 21, 2013 | Dewalt Planer (DW734)
The drive belt on a dewalt 735 planer dosnot track
Apr 25, 2011 | Dewalt 13 in Planer
Got to:
www.servicenet.com.
Hope this helps.
Apr 23, 2011 | Dewalt 13 in Planer
I need instruction manual book of DeWalt DW 735 planer to replace the blades
Hi mmh9894,
You may view the manual. Click the link below.
http://lib.store.yahoo.net/lib/tylertool/DW735m.pdf
Hope I help you.
Have a nice day!
Thanks for using Fixya.
Feb 24, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
DW735 Planer won't start
my planer seem to skip as it is drawing the board through.
Aug 06, 2008 | Dewalt DW744S 10" Portable Table Saw with...
Measuring Tools & Sensors Logo
53 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
