Question about NorStar Phones
Nortel Norstar ICS configure extension
I need to change the extension of several lines in the office and I do not know how to program this...can u help?
5 Suggested Answers
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Posted on Jan 08, 2009
  • 192 Answers
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Posted on Mar 19, 2009
  • 192 Answers
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
Posted on Mar 25, 2009
  • 60 Answers
SOURCE: Nortel Admin Password Problem
You use the f985 to reset the password. But i cannot publish the password here. It is in your vm manual.
Posted on Aug 09, 2009
  • 856 Answers
SOURCE: Change extension to another line pool
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the show key (top right arrow)
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key till you get to the desired pool(bottom right arrow) .
Press the Chng soft key from N to Y
Press the heading key till the display says Line Pool Access(top left arrow).
The display should say Prime Line
Press the Chng soft key till you get to the desired pool
Press the release key when finished
Posted on Oct 01, 2009
0 characters
1 Points
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
Jan 18, 2016 | NorStar M7324 Telephone
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
Nov 01, 2013 | NorStar Phones
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Nov 23, 2012 | NorStar Meridian M7310 Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
T3716 Norstar Phone
If you know how to access admin programming. Yes, all the phones are probably set to "appear only"you need to go into line appearance for all the extensions and make them "appear and ring" If you find it, you can copy that programming from the phone that is already ringing.
Jun 25, 2009 | Nortel T7316E 2-Line Corded Phone
Trying to make every phone ring when the main phone rings
Well that is better than most people in finding the arrows...
Ok, first you need to know the extensions that you want to program to ring, and the lines, record these numbers... if you do not know the extension numbers and actual line numbers; going to each set, and doing a FEATURE * 0 and the Intercom and line buttons this will tell you the extension number and line number (this also tells you what is on every button).
Then goto your set and put in:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the arrows that correspond.
-> you will now see “TERMINALS&SETS” and press Enter (the top right arrow key)
-> now put in the extn that you want to change (Eg. 227).
-> you should now see the extension number “227: NAME”
-> press Enter (the top right arrow key) again
-> you will now see “LINE ACCESS
-> press ENTER
-> you will now see “LINE ASSIGNMENT
-> and Enter
-> now you can type in the lines that you want to ring on this extension (Eg. 025 for line 5)
-> hit CHANGE till it says "APPR&RING" (Appear and ring means that the line will have a button on the set)
-> hit NEXT to save changes
-> press FIND to look for more lines and change the appropriate lines to appear and ring
-> then the RLS button (the little orange button) to exit programming.
After this programming is done, dial Feature * 0 and look for these new lines.
Good luck.
May 05, 2009 | NorStar Meridian M7310 Phone
Changing names on Extensions
Press "Feature **ADMIN", go to NAMES, Then go to Sets, and from their its just like texting
Aug 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel T7316E
Apr 25, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Phones Logo
158 people viewed this question
Top NorStar Phones Experts
Are you a NorStar Phone Expert? Answer questions, earn points and help others
