Question about HP PhotoSmart Office Equipment & Supplies
How to remove printhead hp 5514 ?
Not printing black
Techvisitor
  • 63 Answers
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Posted on Oct 31, 2008
Crankstart
  • 696 Answers
SOURCE: black not printing / HP OfficeJet Pro L7590
Firstoff,
Good on you for trying all of the above, if your printer has a print head problem you can find out easily by going into your printer toolbox.
Double click the HP Digital Imaging Monitor on the taskbar to the left of the clock.
when it opens click Settings=>Printer Settings=>Printer Toolbox
Ink levels will be displayed there, If the Black ink is showing empty the sensor for that cartridge must be dead(three strikes), Call HP and request a warranty replacement, or, take it back to staples as they generally handle 1 year in the store.
If the black in is showing here then the sensor is good, click the Information tab at the top of this window, then click Printhead Health. If the Black/Yellow is yellow or red Call HP and they should issue you a new one under warranty. If it is green this is not the problem.
Continue by closing that window, then Clicking Settings=>Printer Settings=>Printer Settings
Click on the Colour tab then switch the printer to greyscale and try printing again.
If this doesn't clear the head it may simply be caked or have an airlock.
To ensure it isn't caked simply soak the head in rubbing alcohol 2-3mm deep on the head for an hour or so, then replace it and try again.
Unfortunately if none of these work you may be stuck dealing with HP for a warranty exchange, www.hp.com click support then click chat with an online support technician.
or talk to your staples rep about having it replaced through the instore warranty if you have instore coverage.
Hope this helps FixYa,
Chris
Posted on May 19, 2009
  • 73 Answers
SOURCE: Canon IP 90 clogged printhead nozzles. How to remove printhead?
To avoid drying of the Print Head and clogging of the nozzles, note the following.
*When you turn off the Machine
Follow the procedure below to turn off the machine.
1)Press the ON/OFF button to turn off the machine,
2) Confirm that the POWER lamp has gone out.
This takes a few seconds or as long as 20 seconds.
3) Unplug the power cord from the wall outlet.
If you are using a power outlet strip, you can switch off instead.
When you press the ON/OFF button to turn off the machine, the machine automatically puts a protective cap on the Print Head to prevent the ink from drying. If you remove the power cord or switch off the power outlet strip before the POWER lamp goes out, this capping will not be done properly, causing the Print Head to dry and clog.
* When You are not Using the Machine for a Long Time.
When you are not using the machine for a long time, print or copy in both black and white and in color or pertorm Print Head Cleaning, about once a month to prevent degradation of the Print Head.
Numerous nozzles are installed in the Print Head for high -precision printing. Just as the uncapped tip of a ballpoint pen or marker becomes dry and unusable if it is not used for a long period of time, the print nozzles becomes blocked by dried ink. Periodically printing or cleaning of the Print Head can prevent this blockage.
Note :
*If the printed area is traced with a highlight pen or paint-stick or stained with water or sweat, ink may blur depending in the paper.
*If the print head nozzles get clogged , printouts will become faint or particular colors will not be printed properly.
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
The pattern print confirmation screen is displayed.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
1)
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Posted on Nov 30, 2009
SOURCE: HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
Posted on Jan 15, 2010
  • 79 Answers
SOURCE: hp 6500a plus printhead won't print
Try using this manual - Hp Officejet 6500a Plus Manual
Posted on Feb 28, 2013
Printer won't print black
Replace Print head unit (where cartridges are fixed) or clean it manually..
Mar 12, 2014 | HP Photosmart 5514 e-All-in-One Printer
HP photosmart 5514 won't print black?
Just experienced this on my Photosmart 5514. The problem turned out to be the ink pump inside which primes the nozzles, there is a hose for the colour head and one for the black. The black side was clogged with old semi-dry ink. After removing the hose from the pump, and soaking it in hot water for about 15 minutes I was able to squeeze out the old ink, now it works like new.
Mar 24, 2013 | HP Office Equipment & Supplies
HP photosmart B210 wont print black
Seems to be a common problem - I had it too. I spent a lot of time looking, but never quite found a consistent fix. I fixed mine in a few steps: First, I removed all the cartridges, and cleaned the filters on the top of the printhead (these are the little screens you see when you look at the tray with the cartridges removed). To do this I blotted each screen with premoistened alcohol wipes, changing wipes frequently, until the wipes were clean. I then removed the printhead by lifting the black handle on the right side, and lifting the printhead straight up. I used alcohol pads on the rear contacts (refer to HP's instructions for changing printheads) in a downward motion only. Finally, I cleaned
Nov 10, 2012 | HP Photosmart Plus B210A Multifunction...
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
HP 6940 won't print black-new cartridge installed-prints color but no black
In all likelihood your print head has become clogged at the black ink outlet. Be aware that printheads can BURN OUT if you keep trying to print and there's insufficient ink reaching the printhead. The ink flow is relied upon to prevent overheating of the tiny resistors at the printhead. Best bet is to remove the cartridges from the printhead and then remove the printhead and try to clean it in warm water. You will find many youtube videos on suggestions for cleaning the printheads on HP printers. Do a google search for your model. If all else fails you can order replacement printheads for the part that has failed. They are not cheap so price compare. Oftentimes they will cost nearly as much as a new printer!
May 16, 2012 | HP 6940 InkJet Printer
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
240 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
