Question about Toro Lawn Mower With Toro Power Tools
Easy start self propelled toro lawn mower won't start. New plug, new fuel, clean filter. fuel pump bulb doesn't seem to be compressing...now what
  • 59 Answers
It is hard to tell you that but if you take the the bulb plat of and blow it out it should work but make sure that the gasket is in place it well have a small hole ate the top i think fore the air to go threw it
Posted on Jun 23, 2009
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Lawn mower won't run. Cannot start it.
sometimes the primer bulb gets cracked and wont properly pump fuel into the carb. replacement of the bulb should fix the problem.
Jun 15, 2013 | Garden
I have a new model 20371 tor self propelled mower. Used it once. Won't start
Change the plug.
Check coil / wire.
Clean or replace air filter.
Check fuel tank for debri / grass or dirt.
If there is grass or debri in the gas tank, you need to go through the carbruetor because the jets are possibly clogged......
Hope this works...
Apr 21, 2013 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
My Toro Model 20070 that until now has always started on the first pull, won't start at all now. It started fine last week. It's getting spark (a little more yellow than blue). I replaced the plug,...
Hold the butterfly valve (behind air filter) open with a screwdriver, while somebody else tries to start it. Toro has had problems with atuomatic chokes. If it fires right up, thats the problem! If so, just wire it open, or contact Toro for a repair kit. Try using starting fluid, not carb cleaner, and spray directly into the head through the spark plug port. If you didn't do it already, blow out all the ports in the carb with compressed air, or carb cleaner. Also, be sure the safety lever is engaging correctly (top bar on handle) at the engine. Lawn mowers are pretty simple, so the problem is most likely simple too.
Sep 24, 2011 | Toro Personal Pace CARB Walk Power Mower
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it...
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
My lawn mower starts, then stalls immediately.
the carb will need to be removed and cleaned and blown out or ultrasonic cleaned is best if you can get that done? if not a can of carb or brake cleaner and blow through all the jets the blow out with compressed air
Jul 08, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Toro Lawn Mower With Toro Power Tools Logo
811 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
