Question about 2001 Ford Mustang - Coupe - Base Rack System
Where is yhe fuse for a 2001 mustang power windows
  • 549 Answers
What would be wrong 2001 mustang dr window wont work ,switch & motor good.
Ck power from switch directly to motor, if ok probably a bad window regulator, crunchy sounds? If no power to motor, could be one touch relay
May 19, 2014 | 2001 Ford Mustang
2001 mustang fuse box diagram
I have a 2001 convertible mustang and my dash light were my gas gauge is and my speedometer are that light is out and I was wondering how I go about replacing it? Is it a fuse or a bulb? And I need to replace the fuse for the convertible top.... So if anyone knows which fuses these are I would greatly appreciate your help.. Thank You.
Oct 17, 2011 | 2001 Ford Mustang
Power window fuse location for 2001 mustang
There is a 20 amp circuit breaker located in the fuse box in the inside of your vehicle. It's in the number 43 position (see picture below). I hope this helps you and good luck.
Apr 13, 2011 | Ford Mustang Cars & Trucks
I need to know were the fuse is for the interior lights on mustang gt 2001
Interior lamps are powered through fuse # 7 and is a 15 amp fuse. It is located in the interior fuse panel. The lamps are gounded though ground # G400 which is located in the left rear cargo area.
Apr 08, 2011 | 2001 Ford Mustang
Windows wont go up on 2001 ford mustang dont have fuse diagram
The fuse for the power windows is a 40 amp. fuse in the fuse/relay box located under the hood on the drivers side of your vechicle.
It's the first top fuse (position 12) next to the relays.
To see a fuse block diagram go to this FREE Ford website and download the owners manual for your vechicle. It's location in the manual is "roadside emergencies" page 136.
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Mar 23, 2010 | 2001 Ford Mustang
Half of the fuses in the fuse box don't have electricity coming to them. Do I need to change the wiring to the fuse box, the fuse box itself, or the fuses on a 2001 Ford Mustang?
There is not always power onevery fuse in the fuse box. These days you may find that a circuit is fused on the load side of a circuit such as your headlamps. The fuse for components such as this will have the power coming from the switch, through the fuse and out to the component. In c case such as this the fuse will not be powered until the switch is turned to the on position.
Nov 07, 2009 | 2001 Ford Mustang
WHERE DOES THE FUSE GO FOR THE POWER WINDOWS?
look under the hood and if you fuse block or on the driver side
Nov 02, 2009 | 2000 Ford Mustang
Convertible top won't go back up, can you help?
IT is probably a fuse. Does it work at all? my mustang had a busted cylinder and only 1 side would go up. If it doesnt work at all then check your fuses. With no manual you will have to use a flashlight and shine on them and see if one is blown. IF they all look good then I would go buy a testlight for about $10 and manually check the fuses for power. It oculd be the motor, however that will cost you several hundred dollars and that is if you install it yourself.
Oct 06, 2009 | 2001 Ford Mustang
2001 Ford Mustang - Coupe - Base Rack System Logo
Top Thule Vehicle Parts & Accessories Experts
L Pfaff
L Pfaff
Rocguy
ray012965
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
