Question about Whirlpool Duet GHW9150P Front Load Washer
The "rubber circle" at the front door around the drum has a hole in it causing a leak...I have use a pool repair kit to help for now...can this "rubber circle" be replaced?
  • 6,784 Answers
HI, you can order this drum seal from whirlpool if you choose. it is replaceable.
Posted on Jun 22, 2009
SMALL HOLE BOTTOM OF 15 x 4 metal frame pool. believe a small pebble caused it. water leaking out is there a way to save the poolwithout draining and taking it apart?
Try this....
You will need;
Pool liner patch kit
Goggles
Body weight to hold you down while doing repair under water.
Most liner repair kits have instructions on wet applications. Cut a piece of the liner kit fabric to cover the entire hole plus at least 1/2" around. You will need to dive in with a mask/goggles to see the hole. Put a thin layer of glue on the patch and spread evenly.. Fold in half on the glue side and go down to the bottom of the pool. Note...The weights will help you stay at the bottom for this part of the repair.. QUICKLY!!! while holding the patch next to the hole. open the patch and place on the hole and push firmly for a few seconds. Come up and place your foot on the patch and hold for 3 minutes or so. Should work...It took me several times to master this technique when I had a hole at the bottom of my pool... Caution!!! You don't need a lot of weight to stay at the bottom. Test from light to heavy until you think you have enough to do the repair..
Good luck and hope this will help you!! If this works for you, please rate!
Jul 19, 2011 | Intex Easy Set Pool 15x36
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a hole in the grey rubber seal that connects between the drum and the front. water leaks through and down the inside front panel of the machine. Can i buy a replacement part? How hard is it to...
You can buy a new door seal.
It is a fairly tricky job to do it your self.
To get some one to fit it, I would expect you tp be paying around £70.00 to £90.00 depending on who you get, so get some quotes.
Hope this helps.
Dec 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Water standing floor of 1991 corsica
That can be caused by the door or window seals. Around all your doors there is a rubber seal, this seal can degrade and allow water into the interior. There are also seals around the windows and front and rear windshields. If I were you I would visually inspect all the rubber seals on all your doors and windows, if any part of the seals is worn it should be replaced. You can buy universal weatherstripping kits off the shelf at any auto parts store to replace any of yours that are bad and it's pretty easy to install. You can also pick up a tube of silicone sealent to seal any small gaps or cracks in the existing seals.
Hope this helps
Feb 18, 2009 | 1991 Chevrolet Corsica
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Whirlpool Duet GHW9150P Front Load Washer Logo
159 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
