Some remotes are programmable. In order to do this, you may need a code to do that. Check your manual in your Bose sound system for a code. if you don't find it there, check your DirectTV remote setup guide. It should list it there. It may be under Bose, sound systems, or other. Once your remote is set up and configured for your sound system, you'll be able to control sound with your remote.
SOURCE: Remote won't turn on the system. Has new
Unplug the speaker plug and the power plug. Let it sit for a minute. Plug the speakers in and then the power and try again. Hope this helps.I have seen this many times and this is usually the solution.
SOURCE: remote control codes for a Bose Cinemate
I would contact ur nearest Bose dealer or Contact the company through the website to get a replacement remote, you will of course need the serial number for the product when you contact them, using a universal remote can make things easier but you will not be able to access most of the functions without the original
SOURCE: code for uverse cisco box to bose cinemate series
hi i do have here a couple of codes for bose
4000, 2130, 2215, 2276, 6060,
5007
hope this helps! goodluck!
SOURCE: do not have remote for bose cinemate speaker
It would be our pleasure to help you with that.
Here are some steps that will help in addressing your DISH Network remote toyour Bose Home Theater System:
1. Press and hold the desired Mode button until all mode button back lightscome on, then release.
2. Use the number buttons to enter the device code corresponding to theequipment.
AUX Mode: Before entering the device code:
Codes for Bose Amplifier: 656, 761, 639.
3. Press the pound (#) button
Note: The light will blink off after each digitis entered and then return to a steady light.
4. Press the POUND (#) button.
If the code entered is valid for the remote, the mode lightflashes three times.
Although we are sure this will help, we cannot guarantee that it will work for your particular make and model.
Thanks for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
SOURCE: how do you have dish network remote control work
We would be happy to help with that. Here is a list of someof the codes that we have for your Bose Cinemate Digital Home Theater System: 656, 761, 639, and 664.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose system provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose audio system. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
