Question about Sony Cameras
Why am I getting pictures with curved edges edges
    Problem Solver:
  • 20 Answers
Hi Ian
What you are suffering is something called barrel distortion which causes images to appear spherised or "inflated". Barrel distortion is associated with wide angle lenses and typically occurs at the wide end of a zoom lens. The use of converters often amplifies the effect. It is most visible in images with perfectly straight lines, especially when they are close to the edge of the image frame
the way to solve it is to try not use the end of the of the zoom of your lens. Above 20 mm you should be fine. If this is not possible then you can correct the effect in programmes like Photoshop
Hope this helps
Posted on May 19, 2014
In what direction should the plastic, 8-blade, aftermarket replacement for the metallic OEM fan turn when installed?
Find me helpful, the feathered edge is always the trailing edge. Find my other posts to your same question helpful, The B side, thick edge goes towards the engine on your belt-driven ford ranger fan. This is not rocket science. in-direction-plastic-8-blade-u40lsvyytnuesyuv3fbafhtd-1-0.gifa picture just 4u.
Jan 01, 2015 | 1987 Ford Ranger
I have a Samsung HL-T5676S DLP TV and the picture just recently started to look curved. In the middle of the screen it's straight but on the sides it starts to curve up. Any idea of what could be causing...
make sure you do not have anything sitting on the top of this tv. I have seen this on my tv by just gently putting pressure with my finger on top the screen starts to curve up at the edges.
Jan 14, 2010 | Samsung HL-T5676S Television
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
GE 52 inch projection tv picture is dancing
First a couple of things:
1) Could you please try to describe the picture a bit. Is it curved toward the center from the top and bottom?
2) Can you please update this with the model number?
With the description thus far, I suspect a few bad connections in the convergence circuit, but with the info requested above, I should be able to confirm that and provide you with some repair options.
Hope to hear back soon.
Thanks,
Dan
May 05, 2009 | GE Televison & Video
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Mar 13, 2009 | RCA P52937 52" Rear Projection Television
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
TV picture curves
This is a convergence problem and is usually either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Locate the convergence ICs (large black Ics attached to a heat sink and marked STKxxx). Resolder the pins first. If that fails to resolve the problem replace the ICs.
Keep us posted.
Dan
Nov 07, 2008 | Mitsubishi WS-55807 TV
Toshiba 36a43 no picture
reset the settings using the user manual then the problem will be solved
May 13, 2008 | Toshiba 36A43 36" TV
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Cameras Logo
50 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
