Question about Maax Home
Can't turn on Whirlpool
I have a Maax Hydromax studio 3 pc which is discontinued now. It use to work but now willn't turn on. How do I Fix
  • Doug Whittal
    Doug Whittal May 09, 2014
    I purchased the unit Jan/2001 and I believe the Model # is 100099 I tried to download the owners Manuel but its says its discontinued. Before I used to push to button in to start the unit now nothing happens, I checked and I do have power to the unit. What would be my next step as there is not that much room to work when I take of the side panel.
  • Maax Master
  • 717 Answers
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Posted on May 13, 2014
4 Suggested Answers
  • 10 Answers
SOURCE: I don't know how to work my Maax hydromax double
Try to downlaod the manual from the maax website. Hopefully you can find the model #. Look around in the pump acess area for it. If you cant find it try to match it up with a current model image from the website or do an online image search. All major companies offer there liteture available online somewhere, maybe under a seperate tab, on the product page.
If this does't help you should post again and be more specific i.e. what can't you get to work? Tubs these days have many different feaatures. Also model # and estimate what year it may be.
Wish I could have been of more help.
Sincerely, T. Wood C&F Enterprises a plumbing contractor.
Posted on Oct 08, 2009
tunde007
  • 2382 Answers
SOURCE: Maax bathtub (I believe Saturna)
Hi, the from your explanation it's quite obvious that the controller is faulty and needs to be replaced. You can try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada.
Posted on Mar 01, 2011
uspartscente
  • 717 Answers
SOURCE: The proper way to reset the controls on hydromax
Turn the circuit breaker off for about 2 mins then turn it back on.
Rod
US Parts Center
888-521-6183
Posted on Apr 09, 2013
Maax hydromax whirlpool
wire an extra thermostat to it..have it control the heat
Jan 08, 2014 | Maax Home
We don't know how to operate our maax hydromax system. We moved into our house and the tub has never worked. We get a message no h2o and then sometimes it will do a countdown from 10. Is there a
This sounds as if the low water sensor may not be working. They are designed to know when the tub has water in it and then the motor will start.
What is the model number of the control box under the tub that the pump plugs into?
If we can figure out the control then we can find a solution for you.
Rod
www.uspartscenter.com
Jan 27, 2013 | Maax Home
Where is the filter located on a maax whirlpool drop-in tub
As far as I know you do know have a filter. I have read my instruction manual and it does not mention a filter at all. I have the Topaz 6036. To clean it you are to fill your tub with water and put in dishwasher detergent and let the tub run for a few minutes. You can also add a small amount of bleach.
Dec 17, 2011 | MAAX PALACE 6-JET HYDROMAX DROP-IN BATHTUB...
What does CO1 error mean on my Maax whirlpool
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on, if that doesn't fix your problem, then remove the access panel to the mechanical space in your tub and there are one or two reset buttons in there which can trip and need to be reset.
May 29, 2011 | Maax Calla 7242 Hydromax Whirlpool -...
E06 error--how do you get rid of flashing this error and what causes it in the first place. Thanks
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
Feb 10, 2010 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Maax infinity hot tub error code clfl dont have the manual
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
Jan 26, 2010 | Maax INFINITI HYDROMAX AIRPOOL II CORNER...
WHAT DOES THE WARRANTY COVER
It all depends on the manufacture, Jacuzzi, Aquatic, Maax. They all have different warranties and what is covered. Best to call or e-mail the manufacturer of the tub with the date of pruchase and serial number.
Aug 27, 2009 | Maax Kashmir Hydromax Whirlpool with...
Cold water and jets don't work
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Dec 16, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Dec 12, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Home Logo
209 people viewed this question
Top Maax Home Experts
Mike
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
