What is new to you might not be so new. Sometimes these things can sit on a shelf for months and you buy it not knowing how long it has been there in that store. Being that the belt is possible plastic it wears even if its not being used then it gets old and cracks now you have to have it replaced. Your best bet is to always check to see how long the equipment have been sitting on the shelf before you buy it.
SOURCE: How do I replace the transfer belt on a Lexmark
To replace the transfer belt open the front door, as if you were to replace the toner. Once the front door is open then remove the photoconductors one by one make sure not to touch the surface of the photoconductors also make sure not expose them to light for a long period of time. Once you remove the 4 photoconductors then you should be able to see the transfer belt, just unplug the connector at the top, then release the two plastic flaps on the side and lift the transfer belt. That should be it.
SOURCE: Okay...we have a Lexmark C935 Color Laser Printer
You are correct.Transfer belt is expensive but it does last for 600K pages.You have no choice but replace it.
SOURCE: Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
SOURCE: I have replaced my Lexmark
Please try to check if the transfer belt is properly installed. Turn off the printer for at least about 30 seconds.
If you need further assistance please contact Lexmark Technical Support Center.
