Question about Canon PIXMA iP1600 Printer
Cannon pixma mx320 - Canon PIXMA iP1600 Printer
4 Suggested Answers
  • 1739 Answers
SOURCE: I have a Cannon Pixma
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
  1. Press <Stop/Reset>.
  2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
  6. Close the Feeder Cover.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    When rescanning the document after clearing the error, rescan it from the first page.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
  3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
  4. Open the Document Cover and pull out the document from the inner side.
  5. Close the Document Cover.
    Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Posted on Dec 12, 2010
SOURCE: setting up a canon pixma mx320 to fax
ISome fax go through but some do not
Posted on Mar 13, 2011
  • 40 Answers
SOURCE: I bought a new Cannon
Cannon cartidge numbers are quite confusing to say the least, but your printer requires PG-510 and CL-511, PG is black and CL colour.
The 210/211 is a non european number, but they are the same as CL-511 and PG-510.
Hope this helps.
Posted on Jul 01, 2011
My cannon MX320 printer light are flashing both the on and alarm button - message contact service center, printer error has occurred at the botton of the sceen it shows B200
This error refers to a voltage problem within the print head. Usually the fix is a new print AND the main logic board.
Personally i feel its an end of life error and you should consider replacing the machine as the cost of repair is more than it would be to buy a new printer.
Sorry
Aug 25, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I need a disk for my cannon mx320 mine got lost
You can download all the contents of the CD from HERE, but you'll need to select your operating system, (O.S) [eg. Windows xp, windows vista, etc..] and Language. You'll see both the options on that page. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jul 06, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I bought a new Cannon PIXMA MX320 with no ink cartridge, the manual says that it requires PG-210 & CL-211, while the cannon site says it works with the PG-510 and CL-511. so my question is do they both...
Hope this helps.
Jul 01, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Tengo una impresora cannon mx 320 La impresora no imprime y me da el siguiente aviso en pantalla; ERROR DE IMPRESORA 5200
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Feb 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I need a manual for my mx320 where can i get a copy
Hello
You can get the manual from Cannon MX320 form Here
http://software.canon-europe.com/products/0010697.asp
You can find the manual down list as user guide
Hope this helps, if so do rate the solution
Jan 03, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Canon PIXMA iP1600 Printer Logo
old marine
old marine
