Question about Caroma toilet - water saving Sydney Low Profile 270 elongated 622330-609100
Why is the cistern noisy when refilling
Supposedly an ultra quiet cistern refill but I can hear it another room, should it be this noisy
    Top Expert:
  • 12,650 Answers
Remove lid and look where refill hose is located should be attached and in fill tube [center tube ] if it is than your toilet s noise is normal --you can knock it down a little by turning down the water pressure[turn the external valve on the water line going into toilet ] turn it a little this will also slow refill time as well --and as to ultra quiet that s for the flush mode not the refill mode
Posted on May 14, 2014
2 Suggested Answers
SOURCE: I have a 1998 Caroma Reflections cistern p/n
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Posted on Sep 29, 2010
What type of power steering fluid does a 2002 buick lesabre take
I've found that SeaFoam TransTune works wonders and often quiets pumps that are a bit noisy. If the fluid in it is particularly dark you will want to suck out as much as you can with a turkey baster before refilling it.
Feb 20, 2015 | Buick Cars & Trucks
How to mend a running gural vitrifiye toilet cistern
With lid removed, look down into it and remove and replace the black rubber thing in the center. This is the flush valve and is worn to the point where is no longer provides a tight seal allowing water to pass and run into bowl. Also, could be something underneath it not allowing it to seat properly.
Aug 26, 2014 | Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
Fluidmaster 400
I installed a fluidmaster 400 and the refill cycle is very noisy. You can hear the water running thirty feet away. Any thought?
Aug 12, 2013 | Plumbing
Vitra cistern parts
it could just be bad water pressure how are your cold taps in the same room?
have you used bloo loo type things in your cistern? there may be a blockage in your inlet or a build up of lyme.
check this
Jun 17, 2013 | Home
How to stop a toilet from flushing on its own
What is happening is that water is seeping out of the toilet quietly until the level drops low enough in the tank thus causing it to refill on its own. Solution replace the flapper.
Jan 21, 2013 | Home
Stylus cistern flushes by itself occasionaly
There is water leaking into the bowl. When the water level gets low enough, it calls for refilling the tank. Leaky valve or worn down washer in the cistern.
Jan 09, 2013 | Home
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
I just refilled the cartrige, but it says the ink is low, My printer brand is Lexmark2400.
You may have a non refillable cartridge.
Lexmark has an interesting development with their inkjet cartridges which they began some years ago with toner cartridges. A court decision required Lexmark to allow their cartridges to be refilled. However, Lexmark would naturally prefer that you only buy from Lexmark. Thus, Lexmark has developed the following system:
  • Lexmark offers for sale two different versions of the same cartridge:
  • The regular version (#23, #24, #28, #29, #41, #42) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
  • The "A" version (#23A, #24A, #28A, #29A, #41A, #42A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version.
Jun 23, 2008 | Office Equipment & Supplies
Caroma toilet - water saving Sydney Low Profile 270 elongated 622330-609100 Logo
300 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
