Question about Coffee Makers & Espresso Machines
Partial cups of coffee sometimes..with new keurig
5 Suggested Answers
  • 28 Answers
SOURCE: keurig coffee maker does not make a full cup,
Check the needle to make sure it's not clogged. You can completely remove the k-cup holder and wash it out with your kitchen sink sprayer to help remove any obstructions. The manufacturer even recommends using the tip of a small paper clip to help push out any debris if needed. Then try brewing a cup of just water on the largest setting without a k-cup in it. Hope that helps! Best of luck...
Posted on Feb 07, 2010
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
  • 3 Answers
SOURCE: Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
Posted on Aug 05, 2010
everybody96327
SOURCE: Keurig B60 only filling partial cup
Hi, Parts can be found at amazon, click here and take a look:
Amazon com Keurig B60 parts. Wish you best of luck. Mike
Posted on Jan 07, 2015
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
The machine is brewing more than a partial cup it says on the display DE-Scale?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 11, 2011 | Keurig Platinum B70 Coffee Maker
Partial cup fills some water returns to reservoir i've already cleaned the small holes and descaled
heatman101
Jul 13, 2011 | Keurig B60 Coffee Maker
It's brewing partial cups. We've descaled, checked the K cup, and run water through without the K-Cup
heatman101
Jun 15, 2011 | Keurig B60 Coffee Maker
On my Keurig coffeemaker, I de-scaled it with vinigar twice, but I now get partial cups when I try to brew. The amount of coffee is reduced with each brew.
heatman101
Jun 13, 2011 | Keurig B70 Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
