Question about Samsung CW29M64NS 29" TV
Str x6750 why the o/p voltages are more than 150 volts?
  • Sita Kansra
    Sita Kansra May 28, 2014
    After replacing STR x6750 and optocopler the problem was soved Thanx a lot
    New Friend:
  • 5 Answers
More than 150V is how many volts precisely? Put a bulb of 220V 60W across the capacitor and test again. If voltage does not drop to normal, check power supply components or replace the STRX6750. Don't forget to replace the optocoupler too.
Posted on May 12, 2014
    Top Expert:
  • Samsung Master
  • 75,320 Answers
Check all the other components, at related SMPS circuit, for any loose solder terminals. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on May 10, 2014
Tv back light problem
If the backlight is glowing then there is no problem with backlight. Check the high voltage circuit first where the 120 volts AC enters the TV. Then first the transformer, check the DC voltage on the capacitor - should be at least 390 volts. If not, replace it. The one is 100 uf rated450 volts. When I check my high voltage it was only 380 volts. So, I used two capacitors in parallel 150 uf and 220 uf (both rated at 400 volts, and that fixed the problem.
Jan 05, 2018 | Samsung Televison & Video
After turning off my Samsung LED TV, the Stand by light will not come on. Unplugging the TV for a few minutes and plugging it back in will bring it back. Is this the Power Supply?
Yes, it is the high voltage circuit. My Samsung got worse and worse until it did not turn on anymore. Searched the web and said that was the capacitor rated 100 uf at 450 volts. I measured 380 volts at the capacitor. Had saved a 150 uf and a 220 uf at 400 volts. Tried the 220 uf first but was only a little better, but both 150 uf and 220 uf in parallel fixed the problem. Measured the voltage at 391 volts.
Nov 07, 2017 | Samsung Televison & Video
Voltage gauge drops alternator squeals. When using plow
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY CABLES/TERMINALS
LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
INSPECT BELT(s),
TEST ALTERNATOR OUTPUT (ON THE VEHICLE,'NOT' BENCH TESTED),
1 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW not ENGAGED
2 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW ENGAGED ALT OUTPUT SPEC ????
Feb 04, 2014 | GMC Sierra Cars & Trucks
I have a 1990 f-150 with a 300 straight 6 cylinder. I am getting voltage from battery to coil but no spark coming from it. I have replaced it and distributor also and still no spark. anyone got any ideas?
Replace the coil and ensure that you get the correct coil voltage for the vehicle Coils come in to voltages Straight 12 volt coils that start and run on 12 volts and other that start on 12 volt and run on 7 volts. Check if it needs a resister with it.
Apr 23, 2013 | Cars & Trucks
What would cause too much voltage output on a '96 f 150?
More than 14.5 volts- engine running ?
Only the alternator puts out current &
measured voltage
So bad regulator or some problem with
the diodes if you have AC Ripple as well
Feb 22, 2013 | 1996 Ford F150 Regular Cab
Motherboard, the inverter output voltage
Inverter output can vary, but anything greater than 150 volts with a high impedance meter (with a capacity of 2000 volts) can be considered good. The meter loads the circuit by itself and normally the RMS voltage that most meters register is lower than the peak to peak voltage of the circuit. If a scope is used, use a 10:1 reduction probe, and your voltages can be anywhere from 300 volts to 1200 volts with 650 to 750 being the normally accepted good range. Where your brightness control is set will have direct impact on the voltage you see.
Nov 01, 2012 | Acer Aspire 5920-6727 Notebook
UPS does not supply power under 150~ volts
UPS will provide constant voltage out put.
The average working condition of UPS is 170 to 270 volt.
Below the level may not work.
Jul 20, 2012 | Computers & Internet
Voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
Aug 01, 2009 | Coleman Powermate Powermate 5000W...
TV shut off and won't turn back on??
Sounds like my Samsung. Searched web and said to check the capacitor (good thing there was only one capacitor) rated at 100 uf at 450 volts. Measured at the capacitor - has only 380 volts. Have a 150 uf and 220 uf at 400 volts. (Samsung's capacitor was 450 v.) Worrisome, yes. Tried all combination, but only 150 uf plus the 220 uf would work. Measured 390 volts.
Nov 07, 2017 | LG 42PC3DV 42 in. Plasma EDTV
Samsung CW29M64NS 29" TV Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
