Question about Robot Coupe Food Processors
How do i replace a pin assembly in a robot coupe?
3 Suggested Answers
  • 81 Answers
SOURCE: how do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Posted on Jul 25, 2009
  • 81 Answers
SOURCE: How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. capt_rick1912@yahoo.com
How to remove and install on/off pin for robot coupe r2
Thanks so much for the advice. Any idea what size TORX is required?
Jan 08, 2012 | Robot Coupe R2Dice Ultra Food Processor
Remove pin & replace in work bowl
it takes two to do this. there are two holes on the bottom part of handle. find something strong to push them in. one person pushes them in and have other person with pliers pull on the plug that you need to remove to get to broken pin. after that...replacement is easy
May 14, 2011 | Robot Coupe R2U Ultra Food Processor
We have a r6n processor. The part that goes on to the base is twisted and won't move in either way. The locking pin is there but cannot be used. It is almost as though it is cross-threaded. What do we do...
Was your product purchased in the USA? I did not find your model number listed on the Robot Coupe website:
http://www.robotcoupeusa.com/
You may be able to find a parts diagram for a similar machine that might assist in understanding the assembly and how to take apart. Unfortunately you need to have an account which would be established when you registered your machine. Other option is to use the search function and find a local service dealer:
http://www.robotcoupeusa.com/support/
Feb 15, 2011 | Robot Coupe R6N Food Processor
I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
Dec 29, 2009 | Robot Coupe R2U Ultra Food Processor
How do I replace the spring on a robo coupe?
Are you referring to the spring in the cutter bowl? You will need to remove the retaining nut. The spring will then come out. the part number for the spring is R1776. Whole assembly part # R242.
Are you referring to the spring in the on and off switch? You will have to replace the switch. If you call Heritage Food Service Equipment, they will be able to fax you a parts break down so that you will know what part is needed. They can most of the time tell you how to replace the parts also. You can contact them at 1-800-253-0200.
Oct 13, 2009 | Robot Coupe R2U Ultra Food Processor
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
Jul 09, 2009 | Robot Coupe Food Processors
Cindy,
Nov 02, 2007 | Robot Coupe R2U Ultra Food Processor
Food Processors Logo
Top Robot Coupe Food Processors Experts
eyecam
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
