Riso gr 1700 Error E01 how we can repair it? Who know? Help us?
Our Riso had 1) error E4, so we clean drum inside. But then when we place all parts ok, and set upp drumm to Riso it come E01 and it seem that drum is wrong situation? What we doing wrong? Who can help us?
Riso gr 1700 e01 error
Riso has the answer on the back page of the manual
May 09, 2014 | Riso RZ220 Duplicator
Gr 1700 drum clean
If it is clean what is the problem
CODE E4 RISO KS800
ink overflow --inside the printing drum there's a small circuit with two pin ( like needles)....there is one shorter than the other, they are very thin... you have to clean them with a small swab and alcohol, be very carefull, don't bend them....hope this be usefull to you :)
Dec 22, 2013 | Riso RZ390 Duplicator
Bonjour, ma riso ks800 marque l'erreur de E4 .Pouvez vous m'aider pour la resoudre SVP? merci d'avance!
HI. E4 REFERS TO "INK OVERFLOW" . CHECK INSIDE THE DRUM, AND CLEAN IF NECESSARY. IF YOU NEED MORE INFO, LET ME KNOW :)
Apr 16, 2012 | Riso RZ390 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Rsio TR1510 Error Code E01
Yes Easy. Get out the Sylinder drum, switch off the machine: open a back cover' on a board press reset then switch on the machine while the drum is out; then insert the Sylinder Drum. the error should be gone.
CHIMUNTU
Mar 21, 2009 | Riso RZ220 Duplicator
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
jasbo
jasbo
