Question about Troy Garden
HOW MUCH OIL DOES A TROY 174HP MOWER TAKE
OIL CHANGE
    Top Expert:
  • 3,698 Answers
Http://www.troybilt.com/equipment/troybilt/lawn-mowers/tb2654-garden-tractor-tb2654?cm_mmc=Google-_-PLA-_-TroyBilt-_-17AR94KK066&gclid=CKCS
Posted on May 11, 2014
clyde2j2
  • 137 Answers
SOURCE: after changing oil in troy built riding mower the
That is a safety feature with a lot of engines, there is a reset somewhere, call your Troy built dealer and ask him, I'm sure he will help. I will be a simple fix.
Posted on May 17, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
RonInFla
  • 86 Answers
SOURCE: where is the oil plug located on a troy bilt mower?
Tilt it over so the oil cap is on the bottom...it'll rest on the handle and hang there...put a container under the oil fill pipe...something shallow like a glad sandwich container works perfect...get a paper towel, and reach under an unscrew the cap...all the oil runs out into the container...it'll fit !!
Wipe the dipstick off clean, and put it aside...take this time to look at your blade on the other side...it "should look" similar to wood chisel at the last 5 inches of the blade on both ends followed by a wing under it...BTW: their $12 bucks new...and worth it !!
Go back and look at the container and be sure the oil is finished draining...take the lid for the container and snap it on and move it out of the way (no body likes an oil spill)...wipe off the oil fill spout, and re-fill...takes about a half a quart, so don't over fill it !!!
your done...
Posted on Apr 17, 2010
  • 152 Answers
SOURCE: troy bilt mower 6.75 hp smoking too much oil...
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
Posted on May 25, 2010
  • 5 Answers
SOURCE: oil and filter for kohler 23hp engine in troy bilt mower
There is generally a pipe coming out of the side of the engine just above where it mounts to the mower frame. It will generally have a six sided cap at the end. Get a pan to drain the oil in that will hold approx. 1 gallon. Most small engines have at most 2 quarts of oil, but this leaves some room at the top to avoid oil sloshing over the side.
Get the proper sized wrench, or an adjustable wrench (Crescent wrench) to remove the cap.
Before you remove the cap, run the engine for a minute or two--not much longer-you want to warm up the oil so it drains well but not get so hot that it burns you.
Remove the plug and allow all the oil to drain into the pan... let it run even only a thin stream is coming out. Many small engines don't have oil filters and it's best to get all the used oil out of them you can.
If your engine has a filter, you'll want to replace it also. You might be able to remove it with your hands, if not, go buy an oil filter wrench of the right size (take your replacement filter as a guide when you go to the store). Be careful when removing the filter quite a bit of oil will come out. Put a pan under it if you can, if not, push a large rag under the filter to catch the oil and stop it from pouring on the ground. Unscrew the filter, then turn the open end upright to catch any oil in the filter. Drain the filter in your oil pan, etc.
When you install the new filter, put some new engine oil on your finger and wipe it around the black rubber gasket. I also like to put some oil in the filter as this gets oil to the engine a little faster when you first start it after the oil change. If the filter is mounted on its side you can still put some oil in it--the filter will absorb it. Quickly screw it on and you won't spill any.
You'll feel resistance from the gasket touching the filter base on the engine, after a couple turns--tighten it only about 3/4ths of a turn more--don't use a filter wrench to install it--they get stuck in use and you'll have a difficult time removing it at the next oil change.
Make sure the cap is screwed back on the drain pipe, then put the correct amount of fresh oil into the engine. You normally pour it into the spout where the dip stick is, or else there is a cap on the engine marked for adding oil. DON'T OVER FILL IT!! Overfilling can cause the oil to be drawn into the carburetor; and may increase crankcase pressure that will cause your seals to leak ,etc.
Air cooled engines rely on engine oil to help cool them. For this reason, keep the oil up to the Full mark on the dip stick--check it every time you use the machine and top off as needed.
A cheap but effective oil drain pan for lawn mowers and lawn tractors is to get an old rectangular gallon jug like antifreeze comes in. Make sure it is completely empty--if you wash it out, catch the rinse water and dispose of it properly. Anti-freeze has a sweet taste that attracts animals, but is highly poisonous. It's also against the law to wash it down a toilet, household drain, or the gutter on the street. Also the auto parts store won't accept your used oil if it has antifreeze in it.
Make sure you have a tight fitting lid on the jug. Lay it on it's side and use a sharp knife or scissors to carefully cut a large square hole out in the side that's facing up. Round the corners if possible. Leave about 1" of the top surface (the surface you're cutting) all the way around. This will make it stronger, and also helps contain oil that sloshes around when you move it. It also will allow you to drain the oil through the pour spout into a jug to take to an auto parts store for disposal.
Old gallon milk jugs are handy to transport oil in but be careful the lids don't pop off due to rough handling. I prefer using an oil drain pan with a large lid over the opening with a smaller lid over the spout. Leave it flat when carrying it and you won't have any oil leak out. Also, don't store used oil in milk jugs as the plastic breaks down quickly and you could have oil all over your floor.
This is a long comment, but I hope it was helpful.
drechsel97
Posted on Jun 25, 2012
HOW TO CHANGE OIL IN TROY BILT 550EX 140CC PUSH MOWER
http://diymaster.siterubix.com/change-oil-push-mower
Apr 02, 2013 | Briggs & Stratton Garden
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How do I change the oil on my Troy - Bilt squall 5521 ? Which oli weight do I use ?
There should be a plug at the end of the oil fill tube or its under the mower by the blade.clean the bottom of the motor and you will find a plug with a square head that a 3/8 drive rachet and extension will fit into.summer time use sae-30.
Dec 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Where is the oil change plug
The plug is under the mower on the bottom of the engine. Make sure you take the spark plug wire off before you work, remove the blade (it needs sharpening anyway right?) and then tilt the mower on its side WITH THE CARBURETOR UP. position an aluminum cake tin under the mower so that once you remove the oil plug using a 3/8" ratchet you can set the mower back down over the cake tin and it will catch the oil. Don't forget to put the plug back in =-)
Jun 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Changing oil in a troy bilt squall 5521
To change oil in a lawn mower you will need to acquire a fluid evacuation pump. Remove the dipstick and with the pump evacuate the old oil into a suitable container. Check your owners manual to determine how much oil to put in DO NOT overfill or the mower will not work. Make sure the old oil gets recycled.
Oct 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Can't find owners manual for troy built 21''. How do I drain oil from engine.
Not knowing what model number mower you have, there are a couple of possibilities for draining the oil.
Number one: You can tilt the mower back on the handle bar and look at the bottom side of the engine for a drain plug that is easily accessible and unobstructed so that the oil would drain straight into a container with the mower elevated on something high enough to get the container under it. Loosen the plug then put it up on the blocks, saw horses or whatever you are using, get your catch container under it and remove the plug.
Number Two: Start the engine and warm it up for a few minutes to make the oil flow easier. Set it up on a work bench with the oil dipstick tube toward the outer edge of the bench. Line up a catch container on the floor below it and tip the mower over on its side and pour the oil out the dipstick tube into the container. Just use caution not to touch any hot parts of the engine when lifting it up. This is the way Briggs & Stratton recommends changing the oil in their engines which do no have an accessible drain plug.
Oct 25, 2009 | Troy Garden
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
50 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
