Question about Miele W4840 Front Load Washer
How do you remove miele W4840 pedestals - Miele W4840 Front Load Washer
2 Suggested Answers
skyblue67
  • 71 Answers
SOURCE: Miele W4840 is LOCKED
hi try pressing in the heavy soil button to take off the child lock, good luck
Posted on Jul 19, 2009
Door is sagging on Miele W4840 Front Load Washer. Is there an easy repair for this?
Hi Dan.
In the past I have found that the sag on a Front Load door can be rectified with a little bit of judicious 'unsagging'.. Unless the door hinge is loose, in which case spanners are needed. you should be able to 'lift' the door back to it's original position.
I've done this many times myself..
Good luck
Nomess
Jan 29, 2015 | Miele Washing Machines
Malfunction, the sentences "waterproof" shown on the screen
Remove the main board and check for moisture within the board, if seen use a dryer to warm off as this can make the board work erratic. Check and clean all the connectors and reset.
Aug 22, 2013 | Miele W4840 Front Load Washer
How to cancel programme once it is activated on Miele W502
Turn the machine off.
Turn dial to finish.
Turn power back on.
Select drain and start.
When drained you can begin again.
Nov 17, 2012 | Miele W4840 Front Load Washer
Miele w4840 door rubber seal relacement
i just replaced rubber gasket on miele w4840 it took lots of patience! there is a retaining wire on spring on front part this is easily removed. next there is a light and water line about 11 o'clock take this apart and unhook water line in order to remove these from gasket. next there is a locking wire on right side at 9 o'clock. i was able to get a flat head screwdriver and loosen the screw you can open about 1 -1.5 inch at this point the rubber seal can be removed. you have to carefully (painstakingly) put the new seal on. make sure everything is lined up right before replacing the wires took me about an hour as the gasket is difficult to put on back part on drum
Apr 16, 2012 | Miele W4840 Front Load Washer
Is there a way to shorten the wash cycle in regards to time(less than 2 hours)? Or is there a rapid wash cycle?
The normal cycle is approx 1 hour. The w4840 has a little more flexibility in wash times.
Dec 25, 2010 | Miele W 4800 Front Load Washer
W4840 water proof system activated how to reset
1. Unplug the washer
2. Tilt the machine forward about 45 degrees
3. Water will start pouring out from the base pan. Have some towels handy to clean up.
4. Put the machine back in its position
5. Plug it
7. You should be ready to go
Causes
- You may be using too much detergent. Try lesser amount next time.
- There is a leak. If using less detergent does not solve it and this message keeps coming back, then the leak needs to be investigated.
Dec 10, 2010 | Miele W4840 Front Load Washer
Jul 19, 2009 | Miele W4840 Front Load Washer
Miele W4840 Front Load Washer Logo
89 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
