Question about Sportsman GEN154 2000 Watt Portable Generator
Can anyone help me with a wiring diagram for a sportsman GEN154 please. Someone unplugged all of the connections and i dont know where the wires go now.
  • MARWAT
    MARWAT May 09, 2014
    Hi thomas jump, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? in which place ,,, in switch box or in coil portion ?
My sportsman 500 wont start not even click battery is good it has done this before I play around for a few days finally it runs dont really know whatI did to fix it it unrelyable like this
Hi, you could try either replacing the battery or charging it.
Or, you could try buying new battery cables if you know how to replace them.
You could also try reading the manual for any additional information. I managed to find a manual online, just click the link below:
Polaris Sportsman 500 HO Owner Manual
I hope this helped, if it did, please rate me! :)
Oct 20, 2016 | Cars & Trucks
I need a wiring diagram as my son connected the battery wrong negitive to positive need to see what all is wrong
There is a fuse link at the Positive battery terminal wire. It will blow to protect the circuits if the battery is hooked up backwards.
It is a smaller gauge section in the wire that melts to save systems. any auto parts store has one
MDS
Mar 26, 2016 | Polaris 2004 Sportsman 500 H.O
2001 Sportsman 500. Where can I get a wiring diagram?
I'm attaching a picture that has 2 wiring diagrams side by side. The left side is the 2000 Polaris Sportsman 500 (Early) wiring diagram and the right side is the 2000 Polaris Sportsman 500 (Late). The Late wiring diagram for 2000 is more than likely either the same or extremely close to the 2001. And they may have just carried it over (the late wiring diagram). I've got a lot of hours on ATV's and Polaris especially - they stuck with what worked and didn't reinvent the wheel from one year to the next (usually). This may not be exact - but it should be extremely close. Hope this helps. Good Luck.
All The Best, Justin Lee
Nov 10, 2015 | Polaris ATV
How come no spark?
ignition not switched on -faulty switch
problem in oil level unit not completing the circuit for the coil
they are know to be a source of faults
Oct 20, 2015 | Sportsman GEN154 2000 Watt Portable...
Sportsman generator wiring
I know this is an old post, but did you ever find out? Im in the same boat ...i just need the 3 or 4 wire locations behind the switch on the left side, not the harness on the right side ..any help?
Mike
Jan 27, 2013 | Sportsman GEN154 2000 Watt Portable...
I have a zanussi DA 4552, a rat has chewed through most of the machines wiring, i need a wiring diagram so i can try to rewire this machine, please can anyone help me with this
No idea to be honest but you must be able to find the colour of the wires at the ends and then re-connect them i would have thought unless its all the same colour wires ,or look at the council scrap yards and see if you see a similar machine and take the wireing out of it but take plenty of pics on the phone so you know where they all go ?.
Jan 21, 2012 | Cars & Trucks
CAN ANYONE HELP IM TRYING TO WIRE UP A CLARION AB213R RADIO CASSETTE BUT I DONT KNOW WHICH WIRE IS WHICH. I HAVE A BLACK CONNECTION WITH FOUR WIRES. RED..WHITE..ORANGE..PURPLE..ALSO A WHITE CONNECTION WITH...
if you go on google enter clarion ab213r wiring diagram
and it should tell you what every wire is.
also enter your vehicles info and look up the wiring diagram for that also
it should be easy from there
Mar 17, 2010 | Car Audio & Video
Sportsman GEN154 2000 Watt Portable Generator Logo
Top Sportsman Electrical Supplies Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
wadingriver
wadingriver
Bill Boyd
Are you a Sportsman Electrical Supply Expert? Answer questions, earn points and help others
