Question about Ouellet Heating & Cooling
How do I turn my thermostat down?
There are only two buttons. Up and down. When I turn it up or down it turns itself back to the same number. There are no instructions. There is a little "thingy" underneith that looks like you stick a pin in there to adjust but " really don't know.
  • 2,509 Answers
I think you may be misinterpreting what it's telling you. The up down buttons select the DESIRED temperature, when it goes back to the same number it's showing you the actual temperature, which given time should eventually reach the desired temperature.
Posted on May 09, 2014
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
How do I turn down my thermostat?.
May 09, 2014 | Ouellet Heating & Cooling
I want to turn off the adaptive intelligent recovery feature on my TH8000 Series programmable Honeywell thermostat. How do I do that?
You only need to turn it off if you are using program mode. Very nice stat btw. Heres a link to the pdf and I will also explain. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1896EF.pdf Use the system select button so that the heat option is flashing. Look at the bottom of the screen and you will see 7 boxes. First one done and seventh one cancel with all boxes in between blank. Now at the same time hold the 3rd and 5th box (buttons) for approx 5 sec. A new screen will appear with a number sytem staring at 0120 with up or down arrows and 20 with up or down arrows. Push the left up arrow till the left number reads 0530. The right number will read 1 if its on. To turn it off select the down arrow so it reads 0. Then select done and your all set.
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
We have a gas wall heater product number 4690011 and we do not know how to start it;
Remember if you smell gas, turn unit manual gas valve off and open a near by window, wait until smell is gone then proceed with these directions,turn manual gas valve back on, turn thermostat down.1.) turn combination gas valve knob to the pilot position and press down knob, if unit has a striker button, push striker while holding down knob until pilot lights, keep knob held down in the pilot position for 20 seconds then let up on knob and turn to the on position, turn thermostat up, main burners should light.
Mar 04, 2010 | Heating & Cooling
0xc18a0206 error on hp photosmart printer
Fro our Fixya community:
Try holding down the OK, Cancel, Black, and Color buttons all at once. While holding them down, press the On button to power it off (You may need another person if you lack large, coordinated hands). Turn it back on while still holding the other buttons down. You will notice it turn itself off before "booting" fully. After it turns itself off, you can finally let go of those buttons and turn it back on normally. This will force a reset and system maintenance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 01, 2009 | HP Photosmart 8250 InkJet Printer
Thermostat too high causing everything to freeze
you can order a new thermostat using the model and serial number off of the refrig. if the model# tag is missing or unreadable you may be able to get a part number off of the part itself. there are numerous online parts provider for appliances.
If yo would like message back with a mod and ser# and I would be happy to get yo a part number. thanks Peyton
Feb 22, 2009 | Refrigerators
Getting error 0xc18a0206
Try holding down the OK, Cancel, Black, and Color buttons all at once. While holding them down, press the On button to power it off (You may need another person if you lack large, coordinated hands). Turn it back on while still holding the other buttons down. You will notice it turn itself off before "booting" fully. After it turns itself off, you can finally let go of those buttons and turn it back on normally. This will force a reset and system maintenance. Worked for me and others.
Feb 16, 2009 | HP Photosmart 3310 Printer
Freezer will not cut off except
you either got a bad thermostat or low on freon if everything is frozen it is the thermostat
Dec 30, 2008 | Freezers
Honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Feb 09, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
70 people viewed this question
Top Ouellet Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Ouellet Heating and Cooling Expert? Answer questions, earn points and help others
