Question about Ouellet Heating & Cooling
How do I turn down my thermostat?.
It is a baseboard heater. When I turn it down, the temp. bounces right back to the original number. There are only two buttons on it. Up and down.
  • 2,509 Answers
I think you may be misinterpreting what it's telling you. The up down buttons select the DESIRED temperature, when it goes back to the same number it's showing you the actual temperature, which given time should eventually reach the desired temperature.
Posted on May 09, 2014
    Problem Solver:
  • 8 Answers
Code Error 53 is "defective outdoor sensor" error.
source: search engine keywords - Code Error 53
I am not familiar with this particular thermostat; however, here's some general t-stat information; I hope this solution will help you troubleshoot.
I'm under the impression that you're dealing w/ a digital thermostat
the two types of thermostats that i can imagine are programmable and non-programmable.
(MYbackground: Like removing the battery to reset the bios of a motherboard within a PC... This is a very similar approach; note: i am not a ACtech, however, familiar computers and building them.)
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat for the group. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
Hard Reset
disable auto & enable manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Posted on May 12, 2014
  • 1,511 Answers
The internal coil or thermistor is defective and can not sense the normal temp. range. R$eplace
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
I have a new Honeywell Round Non-Programmable Heat Only thermostat MFG # T8775A1009. I turned it down to 50 degrees. The room temp. is reading 70 degrees and heat is coming out of my baseboards. Why is...
Make sure the switches on the back of the thermostat is set for hot water heat. If you have more then 1 zone you may a stuck zone valve or a short in the wiring somewhere keeping the boiler on.
Apr 02, 2010 | Honeywell Programmable Thermostat Heater
Will the thermostat shown above that comes with the baseboard heaters shut off when the room reaches that tempature level?
it should,but you should be sure by setting to desired temp and take a temp reading with a digital thermometer as close to the bulb as possible
Feb 05, 2010 | Fahrenheat Built-In Baseboard Thermostat...
I have a baseboard heater in my apartment (small dining area) that has a dial that I can control the heat..the knob has #1-10...what is a good number to set it to and do I keep it on all the time. Thanks...
Hi!
The number you keep it on is whatever temperature that is comfortable to you. The settings on the dial are graduated from #1(lowest-coolest) to #10(warmest). If you want to keep the room temperature somewhat even you need to play around with the settings( one number at a time) until you find what is comfortable to you. Hope I was of help to you.
Dec 02, 2009 | Fahrenheat FBE15002 Baseboard Heater
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Cadet Thermostat
from the mod number it looks like you have electric baseboard. these do not have blowers in them they work off natural air movement. but heat up rather quickly. your gonna have to chk if baseboard is getting power to determine weather or not the t stat or the heater is not working. but first chk your circuit breakers. most heaters are 220v (double breaker)
Mar 19, 2009 | Cadet Manufacturing 6F1500W Baseboard...
Loose power when turing it on
sounds like it is wired incorrectly at the baseboard heater. BUT if it worked correctly before this, then you may have a bad thermastat. Wiring in two baseboards into one thermastat is a bit tricky, each time I do it I have to think it thru before hand to get it right. IF it has never worked right, again you probably have it wired in wrong at the baseboard.
Dec 14, 2008 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric hydronic liquid-filled baseboard heaters
The same comparisons with other forms of electric heat (i.e., radiant, electric strip baseboard, etc.) are the same. The difference is cycle time - the liquid-filled electric heaters turn on and off less frequently than strip-type to maintain thermostat temperatures. This also means that the unit's temperature will swing more widely than the desired average thermostat setting (the liquid's temperature will signal the thermostat to turn off power, but the temperature will continue to climb; similarly the liquid will signal the thermostat that it is cool enough to engage power but the liquid will continue to cool after power is engaged - similar temp swings with hygronic heating systems). Some say that the liquid-filled units are safer, but the manufacturer's installation guidance is usually the same between strip and liquid-filled so both pose an equal safety hazard.
Sep 21, 2008 | Fahrenheat PLF1504 Baseboard Heater
Heating & Cooling Logo
135 people viewed this question
Top Ouellet Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Ouellet Heating and Cooling Expert? Answer questions, earn points and help others
