Question about Riso RZ220 Duplicator
Gr 1700 drum clean - Riso RZ220 Duplicator
  • Riso Master
  • 1,511 Answers
If it is clean what is the problem
Posted on May 09, 2014
I have bad audio static when playing my mini dv tapes on two JVC MIni DC Video cameras model GR-D244U and GR-D370U,need help?
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
Sep 07, 2016 | JVC GR Video Cameras
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
To reset the counter, press and hold the Cancel button until all lights flash in sequence.
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
I replaced the drum in the fax machine and it still say i have only 14 copys left, how do i reset that? I have muratec fax MFX 1700
You are not supposed to replace the drum until it says"replace drum"
Not when it is saying "replace drum soon."...you have prematurely blown fuse in the cartridge so now it will not reset.
Try the following...
Press...PROGRAM,*,*,I(That is Capital I), then ENTER.(SHOULD RESET IT.)
Nov 16, 2009 | Muratec MFX-1700 Fax
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Riso GR 1700 OK light will not come back on ,nor will it release
switch on the machine and press the astrex button left of the zero button. The code that comes on the display would be helpful. or you you could shoot in the dark and reset the machine by switching off holding down the 2 top right side buttons and switching on the machine. Then release the buttons and off and on with machine.
Mar 25, 2009 | Riso RZ220 Duplicator
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
Call Dell. the 1700 has special reset instructions for resetting the drum count.
Feb 24, 2009 | Dell Office Equipment & Supplies
Black marks on the side
It means you need to change out your drum.
Oct 27, 2008 | Dell 1700 Laser Printer
Dell 1700 laser. refilled toner, getting gray background
Check toner darkness settings using the setup utility.
Oct 18, 2008 | Dell 1700 Laser Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
