Super general i'm getting an error 8 on my washing machine what does that mean ?
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
Posted on Jun 23, 2008
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
Posted on Jun 27, 2009
  • 41 Answers
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
Posted on Sep 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: hiaer hw-c1270tve-u washing machine error code 8
It appears your pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
  • 6277 Answers
SOURCE: I have a Bosch Logixx
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Sep 15, 2011
Testimonial: "Thanks - the engineer is coming later today. "
Super general SGW8100(S), what is meaning of error code E61?
think its Insufficient heating (maximum time exceeded).
Possible fault Heater unit faulty; Wiring faulty; NTC sensor incorrectly calibrated/out of position; Electronic board faulty.
Machine Status/Action Cycle paused.
Dec 16, 2016 | General Dryers
Super general SGW720. What is error 'E4'?
Run the machine empty to see if you can clear some of the soap residue, E-4 is "suds lock" error and is usually due to using too much detergent. Switch to powdered detergent and only use about a tablespoon full per load
Apr 22, 2016 | General Washing Machines
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
Super general SGW7100 E1
my washing machine super general sgw7100 has error E-62! how i solve this problem?
Feb 19, 2013 | General Electric WHDSR209DWW Top Load...
Kenmore Super Capacity 3.5 error code E59
see the error code E59= E59 equals no tachometer signal for 3 seconds.
This means that the motor is not signaling to the washer normally and may be caused by a variety of failures within the motor, basket or the control board. Generally speaking, the E59 error requires the service of a Frigidaire professional for resolution due to the technical nature of the ERROR.
God bless you
Aug 01, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Samsung b1245s washing machine
May 07, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
