NEED A KEYBOARD
Need to get the keyboard for laptop
    Top Expert:
  • Computers & ... Master
  • 26,218 Answers
Check out Flea Bay.
Posted on May 09, 2014
Frozen Toshiba keyboard
1.keyboard might be dirty.
2.keyboard in need of replacement.
if you really need to use your laptop, the other option for you is to use a usb keyboard, to help you avoid the hassle in disassembling your laptop.
Jul 07, 2014 | Toshiba Satellite A135-S2246 Notebook
Keyboard Not Working
Keyboard could need replacing. Try connecting a USB external keyboard and see if it works. If it works okay, you need to have the laptop keyboard connections checked. Replace the keyboard if connections appear to be okay.
Feb 08, 2014 | Gateway Genuine Nv55s Nv57h Nv75s Nv77h...
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Keyboard doesn't work
To determine if the motherboard is faulty, connect an USB keyboard to your laptop an see if the keyboard works properly. If so then the laptop keyboard may only need the keyboard connector unplugged and then plugged back onto the motherboard.
Nov 29, 2012 | Gateway NE56R10u Laptop
Bksp,t,y,caps,shift not working
To determine if you need to replace the keyboard, connect an USB keyboard to your laptop and if the USB keyboard functions properly then you need to replace the laptop keyboard.
If the USB keyboard malfunctions too then the motherboard is faulty.
It may not be cost effective to replace the motherboard.
Jul 20, 2012 | Computers & Internet
My acer 3680 laptop's keyboard is not working
The keyboard may be faulty and if so you need to replace it.
To determine if the keyboard is faulty or the keyboard controller chip is faulty, connect an USB keyboard to your laptop and if the keyboard functions correctly then the laptop's keyboard is faulty.
Replacement keyboard is available from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jun 05, 2011 | Intel Computers & Internet
Water was spilled on the keyboard. Dryed out laptop but keyboard shorted out. Everything works fine but some keyboard characters don't type out. Can keyboard be replaced on this laptop?
You definitely need to replace the keyboard on the system.If your system still within warranty and you have Complete Care warranty from Dell this will be covered, if not you may need to pay for it or purchase a keyboard part.
Jul 29, 2010 | Dell Inspiron 1545 Notebook
Need to replace keyboard
I don't recommend to replace the laptop keyboard if you are not very familiar with hardware, though step by step instruction are available in net.
First check whether your laptop is still covered under warranty. If so, search the authorised service provider of your laptop model near to your place. And get the keyboard replaced by them. Sometimes you'll get it for free, if it is manufacturing defect.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Mar 31, 2010 | Acer Aspire One PC Notebook
Need instruction for keyboard removal
You need to remove the keyboard from your laptop?
  1. Open the monitor and push it all the way back so it is at 180 degrees to the keyboard
  2. There is a plastic strip above the keyboard that you will need to remove. start at the right hand side where there will be a small gap where you can prise it off
  3. undo the screws holding the keyboard in place
  4. Lift out the keyboard and remove the cable
Oct 16, 2009 | Dell Latitude CS R Laptop Keyboard Unit (...
My laptop keyboard is giving me troubles problems..
Need to change the keyboard of your laptop. It's usaly very simple in less then 2 minutes. need some very small screwdriver ( check under the laptop the screw with the keyboard sign). You will need to buy a new (or used) keyboard from a computer store or directly from your laptop factory, witch I prefer. When getting the new one, unscrew the those screw under the laptop. Turn the laptop and open the screen up so you see the keyboard. Don't start the laptop.
Laptop are different, but when screw are out, you should manage to pull out the keyboard.
Some times you have (on HP's) 4 slides that push the keyboard down. Slide them outside with a small flat screwdriver. And gently took the keyboard up with your fingers. Now VERY carefuly, look at the back of the keyboard, you should see a cable connected to the mother board or so. Gently pull it out... check if some pins block it if it's not comming out easy. Do this carefuly, it is the only tricky part, you don't want to brake the connectors. Put the new keyboard in the opposite steps. Rescrew it and start the laptop tadada.
Aug 01, 2009 | Acer Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
