Question about Cisco 7921G IP Wireless Phone
Remove headset mode on cisco 7921 - Cisco 7921G IP Wireless Phone
2 Suggested Answers
  • 26 Answers
SOURCE: what is the problem with my cisco 7921 phone it has a blank screen
Does the phone power on at all? If you hold down the red button on the front it should power on. If it is not powering on, either your battery is dead (needs a charge) or your battery or phone may be defective. Try plugging in the the power supply and then turning the phone on to see if it powers on.
Cisco Phone Power Brick
Posted on Dec 06, 2012
Cisco 7972 use headset
You can use a standard PC or cell phone headsets with Cisco phones. With help of our adapters, you can convert computer headset, smartphone headset or cordless phone hands-free into Cisco compatible headset.
Cisco IP Phones
Feb 06, 2014 | Cisco Computers & Internet
Jabra headset phone
either the switch is partially shorted or the pin on your headet has a shorted wire in it somewhere..try a new headset first..
Jan 08, 2014 | Cisco Computers & Internet
What is the problem with my cisco 7921 phone it has a blank screen
Aug 27, 2012 | Cisco 7921G IP Phone
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
VOIP headset PlantroMX500i 72517-01 to use with Cisco IP spa504G
mx500i.gif MX500i 3-in-1 VoIP Headset Sorry your headset + phone combination is not currently listed in our database. Please contact Plantronics Technical Assistance Center to confirm compatbility
Versatile 3-in-1 Headset for Internet/VoIP, cordless and mobile calls
Part Number: 72517-01
Apr 21, 2010 | Radio Communications
Switched from Cisco phone to Avaya phone. Do i
Do you have the cord into the headset port on your phone?
Sep 24, 2009 | Plantronics Voyager 500A Deskphone Adapter...
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Cisco 7921G IP Wireless Phone Logo
172 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
