Does samsung model tx3064w tv have a digital converter built in
5 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: 2006 RCA TV Digetal Receiver
You WILL have to get an upgraded antenna and converter to be able to watch the new HDTV standard. There is no back door or any other way around it. Point blank get a new antenna and converter.
Posted on Jun 10, 2008
SOURCE: Digital TV??
Does the Sharp Model 27U-S50 have digital capability installed?
Posted on Nov 28, 2008
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
konzzz
  • 255 Answers
SOURCE: Does this TV have a digital tuner built in?
i don't think so.but if has it, there should be a setting for that to change from aerial to digital.
Posted on May 29, 2009
I have samsung old tv dvd vhs built but can't get into programming so I can hook dital box and antenna?
Yes. Connect antenna to digital converter box and then connect box to tv antenna connection. Use ch 3 or ch 4 on the t.v.
Oct 28, 2016 | Samsung Televison & Video
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Is the Model F27683GY a digital TV or does it require a converter box
This family of sets was built before digital, so you'll need a converter.
Jan 08, 2011 | RCA F27683GY 27" TV
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
RE:Samsung Model #TCD1341, Manufact./Aug.1995, digital-capable?
No it does not have a HD tuner. The simle way is a Digital Converter box for about $40.00 it will have composit out (red, white and yellow leads) plug these into TV you will have a converted Digital signal that will make your old set
look like a HD set.
Nov 08, 2009 | Samsung TCD1341 TV
Model 55311 Can you pick up digital tv without converter box?
I am thinking that you have a Mitsubishi WS-55311. If this is the case, you will need a converter box to receive digital television signals.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
Sep 20, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
Do I need converter for Sanyo DS24424A manufactured in 2005.
hiya
what you may need is a freeview box unless ur tv has in built digital
rik
Feb 24, 2009 | Sanyo HT27546 TV
Jan 08, 2009 | Toshiba 24AF42 24" TV
Tv Tuners
Hey jp62388,
According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
http://www.dtv.gov/index.html
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
