Question about Canon SELPHY CP720 Printer
Why does my canon selphy cp720 keeps showing out of ink error but its a new cartridge
  • Larno Aucamp May 11, 2014
    Hi dylanandme04, I want to help you with your problem, but I need more information from you. Did you switch the printer off will replacing the cartridge, or is it a compatible cartridge.
SOURCE: Canon Selphy 510
I have a similar problem saying that the cartridge was not installed. Try winding the film on until you can just see the yellow film and try printing again. This normally fixes my problem for that print run, but the problem seems to regularly re-occur. Hope this helps.
Posted on Mar 04, 2008
comaire2004
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Posted on May 12, 2008
SOURCE: can you refill canon selphy ink cartridges
bought new cartridge and print head
Posted on Nov 17, 2009
SOURCE: Canon iP100 ink tank read error, put in new one and won't read
I am having the same issue with the black cartridge error light is on. Three new cartridges create the same issue.
Posted on Dec 13, 2009
SOURCE: cassette has paper in it; fresh ink cartridge; can
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 21, 2009
Testimonial: "That was exactly the information I needed. It still needs a little push on the paper once in a while, but I'm back to printing. THX"
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
Cannot remove ink cartridge in canon selphy
is one of the gear having the problem in the canon selphy cp 760 photo printer ... the last motor gear loses.. just add super gule to it.. due to the gear is loses.. so the print cartridge can`t releass out...and it keep say your cartridge in empty... turn the gear n it free your print cartridge...
now everthings look fine...
Aug 27, 2012 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Iv changed my ink cartridge and now it wont print it keeps saying ink cartridge has been changed
I just got mine working again. Solution: You have to disassemble your Printer. Take a close look at the small round motor inside. Their is a small toothed wheel attached to the shaft of the motor - mine was already lying inside the printer. This wheel hast to be replaced by a tighter fitting one or the original one has to be fixed to the shaft - I used glue, as i had no new wheel.
May 10, 2012 | Canon SELPHY ES2 Printer
Hi there, Canon Selphy CP-720 from a Mac via Time Capsule... Printer tells me on its lcd screen that the ink cartridge is out, I've bought a new one and same message!! Any ideas? thanks
Welcome to Fixya. Can you provide the exact error that you have on the LCD so that i can provide you the steps on how to fix the issue
Thanks
Jul 12, 2011 | Canon SELPHY CP720 Printer
Hi, I am trying to remove ink cartridge, but when I unclip it it doesn't come out, please help!
Hi.
Click Start>control panel>printers and faxes>right click icon of printer >select properties>maintenance
In maintenance you can read there "How to change ink cartridge" just screen instruction.
Jun 18, 2011 | Canon SELPHY CP720 Printer
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
My Selphy ES40 continues to repeatedly print pictures that it has already printed, and I can't get it to stop. As soon as I turn it on it starts printing previouslyy printed pictures. I'm wasting lots of...
check in the printer icon, if any print jobs in q.
next unplug the power and remove the ink cartridges as well .. now insert the power first and then insert the ink cartridges..
this is one way of doing a semi full reset of the printer
Aug 12, 2010 | Canon SELPHY CP720 Printer
I have lost the instructions to set up cannon
here you go mate..tehere are also drivers there http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=14095
www.ziggy-links.com
Dec 14, 2009 | Canon SELPHY CP720 Printer
I lost my cd and need to download the stuff to make it print
Go to CANON SELPHY CP720 support homepage.
Click on The "Drivers & Downloads" tab and then select your operative system from the list to get a list of all the available drivers and software for your printer compatible with your OS. You can also download the manuals from there.
For help on installing the drivers and software or troubleshooting any installation issues, click on the "Support & Service" tab and read or search the FAQS.
Sep 07, 2009 | Canon SELPHY CP720 Thermal Photo Printer
Canon SELPHY  CP720 Printer Logo
179 people viewed this question
old marine
old marine
