IR 1600 displays supply rec tray 1 while there is paper in tray 1
How change paper size iR2018n?
hi am from Ethiopia,on this machion i mean canon IR 2018 first of all on paper tray with indicating arrows secondly display setting(tray setting on device display
Dec 22, 2017 | Office Equipment & Supplies
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Supply rec. paper Tray:LTR
Sorry i said he reset it, he actually cleaned the feed rollers and run a bypass to allign the feed drive unit, I am getting him back in so i will keep you all posted on the outcome
Feb 21, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Ir 1600
That code indicates a laser problem. You can check the door switches on the front of the machines as well as the left lower door.
Jan 25, 2008 | Canon imageRUNNER C3200 Copier
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
29 people viewed this question
k24674
jasbo
jasbo
