Question about Generac Power Systems Commercial Series 60 kW Standby Generator (120208V NG Steel) QT06024GNSN
I have a 60 kw generac with 2.4l that runs on LP. The first time you start it, it will only come up to appr. 1000 rpm and run rough. Shut of and restart and it will start and run perfect. Verified gas pressure at 11", replaced regulator on gen set, verified orfice size 4.97 mm, when you remove intake from Boch govenor it open about a quarter and moves full open when it hits,Any ideas ?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Plz check auto chok ....... but main cause may be in gas kit
Posted on May 09, 2014
Testimonial: "This unit has no choke and not sure what you mean about a gas kit"
4 Suggested Answers
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
  • 10865 Answers
SOURCE: I have a brand new
Since this generator is brand new, I recommend returning it if that is an option you have. IT is unacceptable to buy anything that requires service right off the bat. That said, it is possible that the carb. is out of adjustment, or that it is partially clogged. If you think it is partially clogged, get a can of starter fluid and squirt a little starter fluid into the air intake to keep it running smoothly for two minutes. This will unclog it. J.
Posted on Sep 05, 2010
Generac power management module install
Mount the transformer on the generator. Hard wire it into a 120 vac plug. Run wires to the module and connect to the coil on the relay. Now run the load you want to disconnect while the generator is running to the load terminals of the relay in the module.
Sep 10, 2016 | Generac GUARDIAN Air-Cooled Automatic...
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
250. What causes it to run roughly and lose RPM?
The Miller 212 has a 60% duty cycle. So for every ten minutes of welding the machine is designed to weld for 6 min and cool down for 4 min.
Sep 02, 2015 | Miller Welding Tools
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
Over crank
Over crank is just that, cranking and cranking for a timed period without a run signal. Make sure the fuel solenoid is opening and you have the correct gas pressure. Too much pressure can stop it opening. Then check you have a spark at the plugs, this will eliminate ignition, and you can re-focus on the fuel system. You didn't say it was LP or Nat gas
Oct 06, 2013 | Generac Power Systems Generac 5518 8 Kw...
I have a generac 22kw model QT02224anan that will run for a few minutes then shut down , then the over speed led is lit. It only happens when it is under load or during a power outage. it goes through...
its possible the overspeed is set to sensitive. or your rpm are to high. these are preset in the factory as a safety, check your manual to ensure your rpm speed is in the pre set area. generators will do this under load when you have a big load on them or take a load off. the governor will some times over compensate causing it to trip on overspeed.
Aug 10, 2011 | Generac Power Systems Generac QT02224 22...
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac Power Systems  Commercial Series 60 kW Standby Generator (120208V  NG  Steel)  QT06024GNSN Logo
89 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
Matt Olenzek
Matt Olenzek
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
