Question about Dewalt 5.5HP 8GAL Gas Wheeled Portable Compressor
Air compressor stalls when using tools after keep starting it
I have a LeRoy older model pull-behind air compressor. When it starts up it low idles but shuts off before it builds pressure. I have all the valves open I have low in pressure but the motor keeps dying. I...
I'm not familiar with that model air compressor, I'm assuming this is a rotary screw driven by a gas or Diesel engine? If the inlet valve is open & the air compressor is attempting to compress air while the engine is starting up, it can be too large of a load for the engine to continue running. I would be checking to make sure I followed all the steps of the mfg start up procedure. If you had a reciprocating air compressor driven by an electric motor and the check valve or unloader valve fails and there is air pressure coming backwards thru the piping against the valves, the actual compressor itself becomes too hard for the electric motor to turn over. The amp draw is so large it causes the breaker to trip. In your case you probably don't have any back pressure coming from other machines making it hard to start but if the inlet valve on the air end is open it could have the same effect. If there is zero pressure in the machine and you start the engine. Everything is going to rotate. The inlet valve for the compressor has to be shut somehow to prevent the compressor from compressing air. If it's open, air will be drawn into the air end, the more the engine runs the more the air end will compress the air. As the internal pressure rises, the air end becomes harder and harder to turn which causes the engine to strain. That's a complete shot in the dark. There are many ways air compressors are controlled. There are many types of air compressors. It could be a problem with the engine itself. The bottom line is that you need to be able to know the air compressor is unloaded and not trying to compress air. If it is unloaded the engine should start up and run.
Dec 16, 2017 | Air Tools & Compressors
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Portable generator stalls when load applied
    Connect the air compressor to house plug and check amp draw with tester. More than likely you will find that the initial start amp load is too great for the generator. Do not rely on the information stated on the compressor. Generators and air compressors do not get along. At our repair shop, we find that most contractor /construction type generators that were used for running air compressors had failed or leaking capacitors and were not producing correct amount of power. You could have gen set with weakened capacity and air compressor that is drawing more than stated on plate. Good luck
    Mar 08, 2013 | Hammering
    My air compressor starts right up, runs for approximately a minute, then quits. If left sitting for a minute or two, it will start again, and run for a minute, then stop. If you shut the fuel off, it...
    It sounds like the compressor is reaching the max psi it can hold. At this point can you use a air tool or blower? The reason it comes back on is to keep the psi at running level. It replentishes the lost or used air.
    Bruce
    Mar 31, 2011 | Honda Air Tools & Compressors
    Battery died after 6 years on my 2004 trailblazer, no problems at all up until this time....tried using the air conditioner and the rpm s dropped and car stalled, happens every time, also when i turn n the...
    6 YEARS IS A LONG TIME FOR A BATTERY TO LAST. YOU ARE LUCKY. I WOULD GET A NEW INTERSTATE BATTERY & CHECK THE CHARGING SYSTEM, TO MAKE SURE IT IS OK. MOTOR RUNNING, THE VOLTAGE AT THE BATTERY SHOULD BE BETWEEN 13.90 & 14.80.
    Jan 08, 2011 | 2004 Chevrolet TrailBlazer
    Compressor builds up air, but when i go to use tools looses pressure to point that its not usable.
    how big is the compressor? if its only say 3 cubic foot a minuet that is at free air pressure not at say 8 bar,,,at 8 bar it would only be 0.375 cubic foot,, check to see how much air in cubic feet per minuet and at what pressure your tools need to work on
    if they say 5 cubic feet at 8 bar and the compressor is only 3 cubic feet at 8 bar the tool will only run for a very short time before the compressor air tank has run out of air and the compressor cant keep up with the demand from the tool
    the bigger the compressor and the bigger the air tank the better some times,,,for a hammer tool you need 8 cubic foot at 10 bar
    thats a big compressor!! or a small one for only a short burst of time,,, in short,,,all ways go for a big un? compressor that is!!
    i hope this has helped you out
    Aug 26, 2010 | Hitachi EC12 Portable Electric 2hp Air...
    The compressor turned on pumped up and shut off and wont start up
    Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
    Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Air Compressor stalls when it reaches @ 40psi. Have a
    You need to find an amp probe from someone and use it to monitor the amps as the compressor is building up pressure. If the amps start increasing dramatically as it nears the stall point it would seem that you have a seizing problem or electrical motor problem. This answer only applies to the exact statement that you gave. ( Air Compressor stalls when it ). Mike micmor68@gmail.com
    Oct 25, 2009 | Air Tools & Compressors
    2-stage air compressor's recovery time takes twice as long
    hi is your machine reaching full pressure? if so maybe your problem is with your tool?
    Mar 23, 2009 | Air Tools & Compressors
    Dewalt 5.5HP 8GAL Gas Wheeled Portable Compressor Logo
    35 people viewed this question
    Top Dewalt Air Tools & Compressors Experts
    John Trevino
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
