Question about HP PSC 1210 All-In-One InkJet Printer
Says its printing but it wont print - HP PSC 1210 All-In-One InkJet Printer
    Scholar:
  • 41 Answers
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer. If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website.
Posted on Jun 22, 2009
Lexmark x1150 wont print text but will print pictures
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
Apr 18, 2013 | Lexmark X1150 All-In-One InkJet Printer
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Sep 20, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Yelllow wont print,...changed cartage cleaned
If after cleaning the print head and changing the cartridge yellow still doesn't print, it sounds like there may be a problem with the print head or the board that controls the print head. The print head may not be receiving the signal to turn on. Check the circuit boards on the machine for obvious damage or a burn smell. Depending on the model printer it may be cheaper to replace the printer than to have the board or print head replaced.
May 15, 2010 | Epson Stylus 2200 InkJet Photo Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Canon ip 5000
If the print head moves left and right smoothly on the paper as it is printing and all the other colors and black print is ok the surely the Print Head is faulty, get it replaced and your printer will be OK.
Regards,
Joseph Manoj
+91 9352008418
Jun 28, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
HP PSC 1210 All-In-One InkJet Printer Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
