I accidently erased valuable set of of custom made programs by resetting to factry specs. Any way I can find that lost program?
  • 2,509 Answers
Yes, remove the drive immediately and do not use it. Everything you do may overwrite the older data. Get a sata to usb adapter (assuming it's a sata drive?) and run data recovery software with the drive connected via usb to another computer. You can do it on the original machine without removal but this greatly increases the risk of irretrievable deletion. Here is an example of recovery software 15 Free Data Recovery Software Tools Free File Recovery Software
there are many others, free and paid for.
Posted on May 09, 2014
How do I reset anti-theft on a 1996 Ford Mustang after replacing the ignition?
Ignition what ? Switch ,Ignition lock cylinder ? New keys ? do they have the transponder pellet in the head. Do you have a security lit flashing when trying to start the vehicle ?
SECTION 419-01: Anti-Theft - PATS 1999 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 11/06/1998 Key Programming -Erase All Key Codes and Program Two Keys
Special Tool(s) > New Generation STAR (NGS) Tester or equivalent
418-F048 (007-00500) NOTE: This procedure is used when a customer needs keys programmed into the system and does not have two programmed ignition keys available. This procedure is also useful when programmed ignition key(s) have been lost or the ignition switch assembly has been replaced, and it is desired to erase key(s) from the passive anti-theft system (PATS) memory.
NOTE: This procedure will erase all programmed ignition keys from the vehicle memory and the vehicle will not start until two keys have been reprogrammed to the vehicle.
NOTE: Two PATS encoded keys with the correct mechanical cut must be available to perform this procedure. One or both of them may be the customer's original keys.
NOTE: If additional keys are to be programmed, refer to Key Programming - Program a Key Using Two Programmed Keys. If the remaining keys are with the customer and are not available with the vehicle, then instruct the customer to refer to the Owners Guide under the "Programming Spare [SecuriLock ® (North America), Safeguard ® (U.K.) or PATS for all other markets] Keys Procedure" for instructions on programming the remaining keys.
  1. Turn the ignition switch from OFF to RUN.
  1. Enter New Generation STAR/Service Bay Diagnostic System (NGS/SBDS). Follow the SECURITY ACCESS PROCEDURE to obtain security access.
  1. From NGS/SBDS menu, select IGNITION KEY CODE ERASE.
  1. NOTE: Do NOT select any additional commands from this menu.
    Turn the ignition switch to OFF and disconnect NGS.
  1. Insert the first encoded key into the ignition lock cylinder and turn the switch to RUN for three seconds.
  1. Insert the second encoded key into the ignition lock cylinder and turn the switch to RUN for three seconds.
  1. The vehicle should now start with both ignition keys.
You'll need to take to the dealer
Mar 19, 2015 | Ford Mustang Cars & Trucks
How to program my VIPER 5701 2-WAY ALARM w/REMOTE START
1. Open a door. (The GREEN wire, H1/8, or the VIOLET,
H1/6 must be connected.)
2. Insert the key. Turn the ignition to the ON position.
The heavy gauge pink wire must be connected.
Program switch corresponding to the number of the
desired function step listed in the following table.
Once you have selected the function step, press the switch once
more and hold it. The LED will flash and the siren will chirp to confirm
the selected functional step. Do not release the Program switch.
Step Function
1 Auto Learn Standard Configuration* (default)
The auto learn configuration will automatically setup the remotes button configuration.
Note: Due to the Supercode protocol, you cannot change the configuration.
2 Delete remotes: This feature will erase all remotes from the memory of the security
system. This is useful in cases when a customer's remote is lost or stolen.
Note:: This will not reset the programmed features of the security system or reset the
Virtual Tach setting.
3 Reset Features: This resets features all of the security system to the factory default settings.
Note: This feature does not delete the remotes from the security system or reset
the Virtual Tach setting.
4 Virtual Tach Reset: Deletes all previously learned values for Virtual Tach, and on the next
remote start sequence the unit will begin virtual tach initialization.
Note: The "Zap" feature on the Bitwriter will not reset the Virtual tach setting.
4. Transmit. While holding the Valet/Program switch, press
the lock button on the remote control. The unit will chirp
to confirm that the code has been successfully pro
grammed. It is not possible to teach a remote control but
ton to the system more than once.
5. Release. Once the code is learned, the Valet/Program
switch can be released.
Nov 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Accidentally erased all images on image card
As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
Apr 18, 2009 | Olympus Stylus 740 Digital Camera
I am unable to find my pictures in my picture card. I didn't not eraser them. Please heip if you know the problem.
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering images.
Apr 03, 2009 | Olympus FE-170 Digital Camera
How to retrive erased images in Olympus Fe-20 degital camera
As long as the xD card was not formatted it is possible to recover the images that were accidently erased. You can go to the following website link and download an image recovery software program that is free of charge.
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost or erased images.
Mar 26, 2009 | Olympus FE-210 Digital Camera
Accidently deleted all photos from camera w. memory card still in
Mar 22, 2009 | Olympus SP-550 UZ Digital Camera
I downloaded a bunch of ringtones and a few wallpapers to my phone. Today the screen went out on me. I can't see the screen to delete the stuff out or to reset it. What do i do
Occasionally you may need to reset your Pocket PC Phone. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when the device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset:
o Use the stylus to lightly press and hold the RESET button on the bottom of your device. The device restarts, and then displays the Today screen.
Warning! Always turn off your device before performing a soft reset or installing/replacing the battery.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on the device will be lost. Only Windows Mobile software and other pre-installed programs will remain
To perform a hard reset:
  1. Press and hold both soft keys on the device. Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
  2. Release the stylus but keep the soft keys pressed when you see the following message on your device screen. "Do you want to erase all user data and restore to manufacture default?" will appear.
  3. Slide open the hardware keyboard, and press R to restore to factory default or press X to exit the hard reset process.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Mar 03, 2009 | UTStarcom Blitz Cell Phone
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
How can I restore factry default?
open your programming manual,or setup manual and read the codes return to factory
Jan 31, 2008 | Symbol LS2208 Handheld
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
