Question about Hipstreet Audio Players & Recorders
How to repair hs-fmt-172lcd
After replacing the blown fuse, it still does not work
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
2004 ford taurus ses
Wich fuse for the radio system would you like to replace? There are 6 of them. Your integrated control panel (dash unit) is controlled by the rear electronic module. This is all part of the multiplexed computer network in your car. I would recommend BEGINNING diagnosis of your radio by scanning your computer network for fault codes, then go from there...
Even if there is a blown fuse, this is an indication that there is an electrical failure which must be diagnosed and repaired. Blown fuses do not cause electrical component failures. Electrical component failures cause blown fuses. Replacing a blown fuse without diagnosing and correcting the fault that made it blow will only result in another blown fuse.
Please also review the following article:
Where's The Fuse?
Apr 12, 2012 | Ford Cars & Trucks
Error code HS on hayward heater H400FDN
check the fusible link if blown check gas pressure
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
I have a Misubishi DLP wd 52825. The timer light keeps blinking and I have no picture or sound. I cannot turn the power on. How can this be repaired? Or what is wrong with it? I have unplugged the TV for...
Most likely the issue is bad capacitors. You need to check for bad 1000uf 16v caps on the dm board and the fmt board. Be sure to checked surface mount fuses on DM and FMT board after you replace the capacitors.
Not to easy of a job due to how much dis-assembly needs to be done. Instructions can be found online on how to do this.
Mar 08, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Feb 20, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green lines thru picture like some open the shades
If the menu is clear without the lines then chances are its failed caps on the FMT board. You can get the V26 FMT repair kit from the following link which also includes instructions for the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
26 people viewed this question
Top Hipstreet Audio Players & Recorders Experts
Tim Rickards
Tim Rickards
Gilberto Beltrao
Gilberto Beltrao
Level 1 Expert
Cassandra
Cassandra
Level 1 Expert
Are you a Hipstreet Audio Player and Recorder Expert? Answer questions, earn points and help others
