Question about Honda Electrical Supplies
Why honda generator engine oil become dark quickly
  • 5 more comments
  • MARWAT
    MARWAT May 09, 2014
    Hi techpak , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? its diesel genrator ? or gasoline
  • techpak May 10, 2014
    Hi, Its Natural Gas Honda Generator 4.5kv made in Japan,Problem occurs when I reassemble the Generator, because plastic cap of oil dip stick broken and drop into the oil chamber & it stuck with connecting rod the engine was Jammed, I replaced the connecting rod and re assemble all related parts. Now the problem is the engine Oil become dusty after few hours of running Pl advice.
  • MARWAT
    MARWAT May 10, 2014
    1. overburning
  • MARWAT
    MARWAT May 10, 2014
    1. overburning
  • MARWAT
    MARWAT May 10, 2014
    2 . and typist setting
  • MARWAT
    MARWAT May 10, 2014
    did u changed the rings? black oil may b due to bad piston rings
    No, I have not changed piston rings, but it was tight in piston sleave
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Does the engine rotate easy I was thinking that maybe you overtightened the Rod to the Crank.
Posted on May 29, 2014
196cc /6.5hp Honda clone generator engine burns oil.Can this be fixed by replacement of top compression ring?
Any engine that burns oil should be given a compression check and then have the compression rings replaced if they leak.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Nov 25, 2014 | Honda Electrical Supplies
I have a Honda EP5000 Generator set with GX340 engine, the problem is that too much oil is discharging from OHV cover into the Air Cleaner via that rubber pipe and spilling out from it. Engine also smokes...
Hi,the quick,but not final fix for this issue is to use a oil additive similar the one-s from the cars,but make sure you are using the one required by the fuel type.The engine is worn out,needs overhaul,soon or later.Good luck,regards
Nov 01, 2014 | Honda 6kw 120/240v, Gx340, Recoil Start...
My honda 2000 generator only runs for about 3 seconds then shuts off
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
Sep 03, 2014 | Honda EU2000IKN EU 2000 Watt Generator 50...
Air filter soaked with oil and head gaskets replaced
check and change the oil it some times the oil become weak and the engine can lift it up and out. also over filled oil is more easy for the engine to life it up and out. check the sump breather aswell make sure its not blocked.
Jan 18, 2014 | Honda Vertical Engine 20 HP OHV ES 3 Amp 1...
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda 5000 generator clear oil out leaking thru air intake
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
Changed the oil, new plug,cleaned the air filter and arrester. tapped the muffler while off and shook out some junk. confident in my gas. my supply runs my two other gennies. so, here the question. unit...
2 things to check , carb bowl for rust/water/debris, if the engine has a oil alert fitted try disabling this ( after double checking oil level ) as these can sometimes become itermittant
Oct 20, 2009 | Honda Electrical Supplies
Honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Nov 28, 2008 | Electrical Supplies
Electrical Supplies Logo
55 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
